battery connections
  • mnrenfro
  • mnrenfro's Avatar Topic Author
battery connections
01 Nov 2017 07:30
#774086
Feeling a little simple here. I bought a new battery for this 76 KZ400 I picked up, but it interferes when I try to install the left side cover. Dimensions are correct from what I can tell (battery dimensions that is).
  • martin_csr
  • martin_csr's Avatar
Re: battery connections
01 Nov 2017 08:40 - 01 Nov 2017 08:46
#774090
What battery did you get & is the stock battery box installed?
Last edit: 01 Nov 2017 08:46 by martin_csr.
  • mnrenfro
01 Nov 2017 08:59
#774093
I bought an AGM battery that is of the same dimensions as what is called out in the service manual for this bike (12N12A-4A-1). As for the battery box, not sure if it is the stock one or not.
  • loudhvx
  • loudhvx's Avatar
01 Nov 2017 18:13
#774117
Just so you are aware, there were two size batteries for Kz400's back then. The S model did not have electric start so it used a smaller battery. The battery boxes were probably different too, but I'm not sure on that.
