'78 KZ1000A2 Ignition Upgrade
  • Hurstman1972
  • Hurstman1972's Avatar Topic Author
29 Oct 2017 19:43
#773978
Need experienced advice on converting an old points ignition to a modern Dyna set up. What model? 2000? Knowledgeable guidance is very much appreciated! Bike is stock, except for Kerker 4-1 and velocity stacks. Thanks!
  • loudhvx
  • loudhvx's Avatar
Re: '78 KZ1000A2 Ignition Upgrade
29 Oct 2017 20:29
#773980
Hurstman1972 wrote: Need experienced advice on converting an old points ignition to a modern Dyna set up. What model? 2000? Knowledgeable guidance is very much appreciated! Bike is stock, except for Kerker 4-1 and velocity stacks. Thanks!
The Dyna 2000 is pretty pricey. If you just want the bike to run and are not worried about maximum performance, you should probably get the Dyna S. You can even use your points coils if they are any good. If they are original, you probably want to get new 3 ohm coils as well.
The following user(s) said Thank You: Hurstman1972
