spark plug wire
  • diamond
  • diamond's Avatar Topic Author
spark plug wire
19 Oct 2017 06:56
#773298
Changing my wires out. They seem a little brittle. Am I looking for 8mm wire? Copper core? 83 kz750L3. Thanks.
Current bikes- 2010 HD street glide,2004 zrx1200r, 2001 wr290x,84 nija900A1 , 83kz750L3, mz250f.
Previously Enjoyed- 77 Kh400, 83 kdx175, 81 kz550, 84 ninja 900, 92 gsxr750, 2000 gsxr600, 02 R1,
01 yz250, 03 yz125, 06 R6, 00 cr125, 85 ninja 900, 07 Victory Jackpot, 83,84,89 RZ350,2006 rmz250
Re: spark plug wire
19 Oct 2017 07:07 - 19 Oct 2017 07:10
#773299
7 mm copper core
Z1 Enterprises lists Dyna plug wires with caps already built-in.
Click here > www.z1enterprises.com/catalogsearch/resu...=&q=spark+plug+wires
Good Fortune! :)
Last edit: 19 Oct 2017 07:10 by Patton.
The following user(s) said Thank You: diamond
  • Nessism
  • Nessism's Avatar
Re: spark plug wire
19 Oct 2017 10:38
#773308
New 7mm copper core wire w/NGK plug caps work great. If you shoot a little WD-40 underneath the OEM outer protector sheath you can remove them from your old wires and then place them over you new 7mm wires.
Z1 used to sell black copper core 7mm wire but I don't see it anymore. Copper core wires w/resistor caps is the stock configuration. If you decide to use suppression core wires you don't need to run resistor plug caps and/or resistor plugs
  • diamond
Re: spark plug wire
19 Oct 2017 16:11
#773315
Thanks guys. I have already ordered the new ngk caps and wanted the black stock look. I will p/u some 7mm copper core wire and have a go. Cheers.
