Not sure what this is called
- tomsbadkz
05 Oct 2017 12:28
Doing my total restoration. Money spent on kid's car and job eliminating my position, Im actually getting it together. Putting the wiring harness on and and looking over all connections. This piece attaches to a small bracket that is mounted to the back of the coil. Looks very dried and cracked and was thinking of replacing. Not sure what it is actually called. Can you Brainiacs help me here? As you can see it is starting to come together.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Re: Not sure what this is called
05 Oct 2017 14:50 - 06 Oct 2017 04:55
Maybe a fuel check switch or outage indicator switch.
outage indicator switch = brake light failure indicator switch. The former term is used in the parts diagram for the 81 650-H1, but the latter is used in the wiring diagram.
Last edit: 06 Oct 2017 04:55 by martin_csr.
05 Oct 2017 15:25
Could examine the color wire diagram for the particular year and model.
- tomsbadkz
05 Oct 2017 16:02
Hey Patton. I just got an assembly manual from an ebayer yesterday. Big electrical schematic in it. I found it. Its the brake light failure indicator switch. Thank you so much for the advice. That's why I come here. Tom
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
05 Oct 2017 21:10
Correct
- Pumpper79
- I'm a crazy pollock with a 1979 kz650sr
01 Apr 2018 08:24
If while just cruising along without applying any brakes the dash brake light warning indicator is blinking, it's telling you that the rear brake light won't come on when the brakes are next applied.
