80 KZ550 pics needed
- Dempsey
30 Sep 2017 06:05
I have this 1980 KZ550 that is being pieced back together and need some experienced folks to guide me on reassembly.
I could use a few pics of the top, left, and right side of the battery box when the side panels are removed. I'm not exactly sure how the electrical pieces in there get attached and wire routing. Can anyone PM me on this? I have a Clymers manual but the pics are horrible. Thanks.
- loudhvx
Re: 80 KZ550 pics needed
01 Oct 2017 08:37
Sorry I don't have any pics. But you may want to mention if you have the "A" standard model, or the "C" Ltd model. They are probably different since the A has points and the C has electronic ignition.
I believe the regulator mounts under the battery. There a few other small brackets in addition to the battery box.
In my signature, you can find several other manuals. You might be able to get some clues from them.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
01 Oct 2017 16:08
The manual should have photos. usually not the greatest, but they should help get some of the stuff sorted, so that figuring out the rest shouldn't be too difficult. there are only so many ways that stuff can be installed. The parts diagrams at Partzilla may be useful.
This may not be much help, but on my 81 650, the igniter is kind of hidden behind the fuse box & the voltage regulator is bolted to the underside of the battery box.
