"Radio Shack" rectifier upgrade for a 79 KZ400?
  • Stockton350
  • Stockton350's Avatar Topic Author
16 Sep 2017 16:47
#771051
HI - I was wondering if anyone has upgraded their rectifier with the Radio Shack unit:
www.amazon.com/RadioShack-25A-Full-Wave-...+full+wave+rectifier
I burned out my rectifier and am wondering if I can swap this one in. Any suggestions/caveats?
1975 CB125 | tinyurl.com/jds9l7q
1976 CB350
1978 KZ200 | tinyurl.com/j3odxo8
  • Nessism
  • Nessism's Avatar
  • Away
Re: "Radio Shack" rectifier upgrade for a 79 KZ400?
16 Sep 2017 18:05
#771060
Does your bike use a common 3 phase generator? If so, I'd get a SH775 and be done with it. I posted links just the other day where there were good cheap units available on ebay.
  • loudhvx
  • loudhvx's Avatar
17 Sep 2017 20:22 - 17 Sep 2017 20:28
#771129
Unlike the big Kz's, the Kz400 only had separate regulator and rectifier with excited field alternator. So separate reg and rec indicate that it is not a permanent magnet alternator.
If the bike has a separate regulator and rectifier, you can use the radio shack rectifier, but there are more powerful ones available, and probably cheaper on Ebay. If you have a 3-phase alternator, you will probably want 3 of those bridge rectifiers. And again, there is probably a cheaper, single 3-phase rectifier available on ebay.
If your regulator and rectifier came as a single unit, then the separate rectifier would be redundant. You would still need the regulator, which would have a rectifier built in.
If your alternator is 3-phase, and originally came with a single reg/rec combo, you can use the one Nessism suggested, or similar ones from modern Ninjas for around $10 or $20.
If your alternator is single phase (two wires) and originally came with a single reg/rec combo, then you will need to find a similar unit. There is a chance you can use a 3-phase unit and leave one of the reg/rec phases unconnected.
Here's the 3-phase version wiring for just the rectifier, but there are probably simpler cheaper options on ebay.:
s3.amazonaws.com/gpzweb/RegRec/GPZdiy3phaseRectifier.html
Last edit: 17 Sep 2017 20:28 by loudhvx.
