Dim Headlight Ever since I changed the handcontrol
- GarbageCanDo
07 Sep 2017 16:12
So I recently changed the handlebar control on my KZ750LTD for the lights, horn, and turnsignals. Right when I changed this the headlight got much dimmer and the brights are even worse. Plus whenever I switch to the bright it goes black and takes a second to turn on at all. The connections look good to me but I may be wrong, any ideas?
- Tyrell Corp
Re: Dim Headlight Ever since I changed the handcontrol
09 Sep 2017 11:05
Your replacement switch or either side of block connector is stuffed, will show high resistance through a meter. Trace the headlight low and high beam wires only.
You could try cleaning the contacts, also check that no black/yellow ground connectioons have been displaced in the headlamp shell.
- jdvorchak
13 Sep 2017 06:22
to clean use ONLY an Electrical contact cleaner. No WD-40 or any penetrating oil. Also clean the connector on the end where it plugs into the mating connector in the headlight bucket.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
