Turn signals not working yet hazards do?
  • BarnyardCoral
  • BarnyardCoral's Avatar Topic Author
25 Aug 2017 21:59
#769770
Since threes a running theme of turn signal issues, I thought I'd start my own thread. 81 KZ1000 CSR signals don't work but the hazards turn on. Thoughts, suggestions?
On a related note, previous owner swapped out original bars so there are no front signals. Anyone got suggestions for good aftermarket fork or headlight mounted signals?
Grand Forks, ND
1981 KZ1000 CSR
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba...." - HST
  • davido
  • davido's Avatar
Re: Turn signals not working yet hazards do?
26 Aug 2017 01:43
#769778
Fit the front flashers and see what happens.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • M_a_t_t
  • M_a_t_t's Avatar
26 Aug 2017 07:52
#769794
You should put some front signals on to confirm, but it could just be your flasher/relay.
On my KZ1100 there are two separate blinking units (IDK what they are called) One for signals and one for hazards. The one for the signals might be bad. Tritan 552, the replacement is ~5 dollars.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
The following user(s) said Thank You: BarnyardCoral
  • martin_csr
  • martin_csr's Avatar
26 Aug 2017 08:42 - 26 Aug 2017 09:03
#769800
The old flasher probably won't work right without the front turn signals. As noted above, get a new flasher from the auto parts store. The Tridon 552 thermal flasher may work fine, but I would get an electronic flasher: Novita LL552. EL12. or LF12.
Last edit: 26 Aug 2017 09:03 by martin_csr.
