Turn signals
  • Kawi-problems23
  • Kawi-problems23's Avatar Topic Author
  • 1980 Kawasaki kz250 single cylinder
Turn signals
25 Aug 2017 11:36
#769739
Hello again everyone:
I have a 1980 kz250 single cylinder and for some reason none of the turn signals work at all. I've checked the fuses and wiring and I can find anything wrong with it if someone could give me pointers to fix it I would really appreciate it. Thanks
  • Mortamie
  • Mortamie's Avatar
Re: Turn signals
25 Aug 2017 11:50
#769741
Might check the switch itself. I had that issue with my headlights and it ended up being the switch.
1977 Kz1000 A1
  • Nerdy
  • Nerdy's Avatar
Re: Turn signals
25 Aug 2017 11:54
#769742
Kawi-problems23 wrote: Hello again everyone:
How did you check the fuse? Looks can be deceiving; your best bet is to use a multimeter to check continuity.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Turn signals
25 Aug 2017 14:43
#769749
Think about that the frame is a part of electric circuit were the voltage have to flow to negative. of the battery.
If the turn signals have not a proper negative ground no current will flow = no turn signals will flash.
  • davido
  • davido's Avatar
Re: Turn signals
26 Aug 2017 01:46
#769779
Check the flasher unit (solenoid?). It might be as simple as that
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
