Ignition coil
- Kawi-problems23
- 1980 Kawasaki kz250 single cylinder
Ignition coil
24 Aug 2017 13:37
Hello everyone
I just bought a ignition coil for my 1980 kz 250 and I would really appreciate some help knowing what polarity the wires are. The first wire is yellow and red and it goes directly to the start button and the second wire goes into the engine. The coil has a positive and negative but I don't want to hook up the wires wrong and fry it. Thanks
Re: Ignition coil
24 Aug 2017 13:43 - 24 Aug 2017 13:59
The yellow and red wire goes to the kill switch (Power + for the ignition)
The second black wire goes to the engine ground (Negative -)
BTW, Hello and welcome to the KZR forum and please introduce you and your bike with some pics.
Last edit: 24 Aug 2017 13:59 by Scirocco. Reason: The second wire is black not black yellow
The following user(s) said Thank You: Kawi-problems23
- Kawi-problems23
Re: Ignition coil
24 Aug 2017 14:35
Thank you so much I'll try it out right now and I'll post a pic of the bike as soon as I have it all back together
Re: Ignition coil
24 Aug 2017 14:49
Please add your bike's year and exact model to your signature line. Kawasaki made single cylinder and twin cylinder KZ250 & Z250 models, so pinning down the exact model will help us help you. Ed
