1979 Kawasaki KZ650 C3
  • pizano14
  • pizano14's Avatar Topic Author
06 Aug 2017 16:28
#768471
new to the motorcycle world and really like the look of the kz650. i found one for sale but the guy that is selling it it tells me that its not currently running, he said that he was installing turn light and then the bike wouldn't turn over but the engine has compression. he also told me that most likely the bike will need an electric started to be fixed. i know cars but not bikes. Does is the issue common, and is it a doable repair.
Re: 1979 Kawasaki KZ650 C3
06 Aug 2017 16:44
#768473
That sounds totally bogus to me. However, here's an extremely easy test - just start the engine using the kickstarter. Ed
  • ajsfirehawk
  • ajsfirehawk's Avatar
06 Aug 2017 17:37
#768476
Sounds fishy to me. At the least you have an electrical problem(s) and/or starter problem. Maybe an engine problem. How does he know the compression is good? Does he even own a compression gauge? Gotta be a better option somewhere.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • pizano14
06 Aug 2017 17:43
#768478
He told me that it does have conpression
  • martin_csr
  • martin_csr's Avatar
06 Aug 2017 17:48 - 01 Sep 2017 06:11
#768482
Don't believe anything the guy says. people forget, don't know & just lie.
For a non-runner, you should get it as cheap as possible,
ps: if you want to ride, you can get a fairly modern motorcycle that actually runs for fairly cheap, less than $3K.
Last edit: 01 Sep 2017 06:11 by martin_csr.
  • pizano14
06 Aug 2017 18:19
#768485
Anybody got any ideas of good bikes for bigginers? Im more into the cruiser style and not a sports bike
06 Aug 2017 19:59
#768492
Maybe a KZ400 LTD if you can find one in good, original condition. Enough pep to ride safely, but not so much as to get you into immediate trouble. Here's a picture of one. Ed
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
07 Aug 2017 05:03
#768500
Ed that's an interesting photo you posted. It appears to be a European spec LTD 500 from what I can see on my phone. I've had several US spec LTD 550's bit they all had a drum rear brake, no passenger strap on the seat and a much shorter rear fender. Where did you get that photo?
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • martin_csr
07 Aug 2017 05:46 - 09 Aug 2017 04:59
#768504
By pizano14: Anybody got any ideas of good bikes for bigginers? Im more into the cruiser style and not a sports bike.
I would look into a Vulcan 500. or Ninja 250 or 500 or other similar offerings from Honda etc.
Another model worth considering is the Vulcan 750, because you can probably find one of those for cheap. It may not be suitable for a beginner, though, as they're kind of heavy. almost 500 #. The VN750 has a shaft drive which would be nice.
Last edit: 09 Aug 2017 04:59 by martin_csr.
07 Aug 2017 06:41
#768505
The Gringo wrote: Ed that's an interesting photo you posted. It appears to be a European spec LTD 500 from what I can see on my phone. I've had several US spec LTD 550's bit they all had a drum rear brake, no passenger strap on the seat and a much shorter rear fender. Where did you get that photo?
I did a Google image search and found it at the link below. Ed
magnusjson.blogspot.com/2013_07_21_archive.html
  • loudhvx
  • loudhvx's Avatar
07 Aug 2017 14:00 - 07 Aug 2017 15:09
#768524
650ed wrote: Maybe a KZ400 LTD if you can find one in good, original condition. Enough pep to ride safely, but not so much as to get you into immediate trouble. Here's a picture of one. Ed
I didn't think the 400-fours came in LTD form. It's definitely in that 400/500/550 four-cylinder family based on the carburetors.
Looking at bigger version of that photo online, the side cover clearly says "400".
The FSM only shows a 550 (Kz550C) in the LTD form with that early style motor and those Tk22/Tk21 carbs. Maybe I'll check the supplements.
Last edit: 07 Aug 2017 15:09 by loudhvx.
07 Aug 2017 15:59
#768532
Here's a bit more info on the KZ400 LTD. Ed
