Cylinders 2 &3 Not firing when hot
- dkoz
Re: Cylinders 2 &3 Not firing when hot
04 Aug 2017 08:10
you should have 3 ohm coils with the s
ive had 2 dynas fail on me this way one running stock coil plug boots.
dyna replaced mine for free very good customer service.
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- sparkybr74mr
04 Aug 2017 09:02
I called Dyna and the Accel super coils are correct with the ignition system. The system has been in use for years. I read somewhere the coils due their age could fail due to heat which is why I replaced the 2-3 coil, but same problem occurred. Dyna suggested I check do a voltage test which again checked out ok. They (Dyna) have sent me a shipping box so I can have them check the unit out.
90 FLSTS
11 FLSTF
11 Ural Patrol
76 KZ900
11 FLSTF
11 Ural Patrol
76 KZ900
04 Aug 2017 17:28 - 04 Aug 2017 17:31
I used the same constellation., except my coils are under my left side cover to prevent heat by the engine.
Dyna S with Accel super coils and ignition cables i have build in 1997.
I have no problems with any parts of it till today, runs like a purring cat..
Last edit: 04 Aug 2017 17:31 by Scirocco.
