trucklite
  • 9er rider
  • 9er rider's Avatar Topic Author
  • Keep a cool tool
trucklite
07 Jul 2017 11:56
#766318
I put a trucklite led in and it flickers,has anyone dad this problem?
  • 9er rider
  • Keep a cool tool
Re: trucklite
07 Jul 2017 11:57 - 07 Jul 2017 12:33
#766319
I put a trucklite led in and it flickers,has anyone had this problem?
Last edit: 07 Jul 2017 12:33 by 9er rider.
  • 9er rider
  • Keep a cool tool
Re: trucklite
07 Jul 2017 12:01
#766321
All my charging equipment is new and works fine
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: trucklite
07 Jul 2017 13:29
#766326
Truck light need 24 Volt and you have only 12 Volt.
This could be your problem with the LED.
The following user(s) said Thank You: TwoCam, GPz550D1
  • TwoCam
  • TwoCam's Avatar
Re: trucklite
07 Jul 2017 14:15
#766332
Think scirocco might be correct. Now unless you use an electronic flasher...... the LED lamps still won't work.... LED's don't draw enough amperage for the old school bi-metallic flashers....
  • 9er rider
  • Keep a cool tool
Re: trucklite
07 Jul 2017 15:58
#766337
Its 12 volt plug and play for motorcycles Its the only led I have. It doesnt bother me but others might think different.I dont ride at night when things go bump.I was wondering If anyone else noticed this.
Thank You
Clyde
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: trucklite
07 Jul 2017 16:11
#766339
Are we talking about a rear light or a flasher light.
Other than normal bulbs LEDs need the correct porlarity
Try switching the cables.
  • 9er rider
  • Keep a cool tool
Re: trucklite
07 Jul 2017 18:12
#766348
Led headlight Its like not getting smooth voltage
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: trucklite
07 Jul 2017 21:17
#766380
Have you checked the voltage on the connectors with a multimeter.
A loosen or oxidate connector / switch in the wiring harness could be the source of a voltage drop.
Try connect the LED headlight temporary direct to the battery with a 10 Amp fuse to to verify the function.
The following user(s) said Thank You: GPz550D1, 9er rider
  • 9er rider
  • Keep a cool tool
Re: trucklite
08 Jul 2017 00:48
#766387
Its a new wiring harness I guess I need to chase it down to the switch and on and see if there is a significant drop
Thank You, Its a place to start.
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
Re: trucklite
08 Jul 2017 21:45 - 08 Jul 2017 21:50
#766452
Is it a "HID" headlamp? Car guys that use those tell me they draw a lot of amps - enough to melt the stock car's headlight wiring when retro-installed on vehicles that didn't come with them,,,
You might need to change to heavier gauge wire to feed the light's current demand and a install a dimmer switch relay to control the light from your handlebar headlight switch.
Last edit: 08 Jul 2017 21:50 by Kray-Z.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: trucklite
09 Jul 2017 07:01
#766465
No eBay APP ID and/or Cert ID defined in Kunena configurationMy HID needed the relay that comes with it as an option. It was recommended and they sent me one free. I had the same issue due to old contacts and such. It doesn't pull any more power running but it needs a ballast to get it started. Uses 1/2 the power the old H4 used. What I like most about it is it has a blue tint and I can tell drivers see me coming better. For some reason the old yellowish headlight was invisible to them.
The following user(s) said Thank You: 9er rider
