Wires Only?
  • Phillip14
  • Phillip14's Avatar Topic Author
Wires Only?
20 Jun 2017 12:33
#764882
Hello All,
First, thank you for all the input on my first 2 post questions. Made for great improvements...
Both spark plug wires are beaten up and could use replacement. I can trace them under the tank but cant find anywhere in the manual that shows if JUST the wires can be replaced or do I have to replace the coils as well because they are attached permanently. I did read a few older posts but could find reference to anyone doing this. can I take off the tank and swap out the wires with new ones?
Thoughts please.
Phillip
  • martin_csr
  • martin_csr's Avatar
Re: Wires Only?
20 Jun 2017 12:39 - 21 Jun 2017 06:05
#764883
What motorcycle is it? Most if not all 70s models & some from 1980 have the spark plug wires molded into the ignition coils, and I think all of them had points ignition.
edit: also the 81 305 which should have points ignition.
Last edit: 21 Jun 2017 06:05 by martin_csr.
The following user(s) said Thank You: Phillip14
  • Phillip14
Re: Wires Only?
20 Jun 2017 12:47
#764886
Sorry,
1981 Kawasaki 305
  • Nessism
  • Nessism's Avatar
Re: Wires Only?
20 Jun 2017 13:00 - 20 Jun 2017 13:00
#764889
Some coils have wires that screw onto the coils. Those are easy to replace using 7mm copper core hi-tension spark plug lead wire. Some other coils have wires that are glued into the coils. Those wires can also be replaced but it's more work; you need to pull out the wire and/or dig it out of the coil using a pick tool. If you go this route you must be careful because there is a spike detail at the bottom of the passage and you need to avoid damaging that. For plug caps, you can get new NGK caps that screw onto the wires. A very doable project.
Last edit: 20 Jun 2017 13:00 by Nessism.
  • martin_csr
Re: Wires Only?
20 Jun 2017 18:13 - 20 Jun 2017 18:16
#764913
By Phillip14: 1981 Kawasaki 305
According to the diagrams at Partzilla the 81 305 has points ignition & the spark plug wires are molded into the coils & not removable.
Most models from 1981-on had electronic ignition with coils similar to those in Nessism's pic. also some 1980 models. But apparently not the 81 305.
Last edit: 20 Jun 2017 18:16 by martin_csr.
