Kill Switch?
- Phillip14
Kill Switch?
14 Jun 2017 13:21
Hello KZrider's
I have a 1981 305. Between the seat and plastic side cover(left side) there is a very small black switch. Its definitely wired into the wiring but I have switched on and off at different times but nothing happens. Any idea what this could be? A "hidden" kill switch? I will post pics tonight after it stops raining and hailing here in the Chicago 'Burbs.
Thoughts, Please.
Thank you
Phillip
Thoughts, Please.
Thank you
Phillip
Re: Kill Switch?
14 Jun 2017 13:47
Someone may have added it as an antitheft device.
Re: Kill Switch?
14 Jun 2017 15:14
If the engine is running and nothing happens when you flip the switch back and forth, it probably is not a kill switch, or a light switch, or a horn switch. It could be for an accessory that is no longer present.
Re: Kill Switch?
14 Jun 2017 19:11
Closely examining a stock wiring diagram may give some clues.
