Doozie of a starter problem.
- Racewayelko
05 Jun 2017 20:34 #763693
by Racewayelko
Keep it rubber side down everyone
Klx 110, TTr125, TTr250, 1982 kz750-N1 (Spectre), Xt-350 (soon to be the new home of a Kz550 engine )
Doozie of a starter problem. was created by Racewayelko
Hi all,
I recently started working on my 1982 Kz750 spectre again (had to stop because of college and other life things). I am having a heck of a time figuring out a starter problem I am having
Problem: When I press the Starter button, nothing happens. No solenoid click, nothing.
What I've tried (All Done In Neutral, on Center stand, kickstand in the horizontal position, Didn't think about the clutch position sensor so clutch is in out position):
Charge battery to 100%
Checked Headlight/Ignition Fuse in left hand side fuse box (checked good)
Checked Run/off switch- Checked good (Get 12v to across when in stop mode, get 0v across when in run)
Cleaned up the contacts on the starter momentary switch (No Change)
Replaced Solenoid with another one I had laying around from my gpz550 (No Change)
Ran a wire from the positive battery post to the negative on the starter switch (no change, no Solenoid click)
The Starter is good, We replaced the brushes and cleaned up the commutator bars less than 1k miles ago
I may have done a few other things that I can't remember, it was a long day
Is there anything I am missing or that I am overlooking? Thanks!
Andrew
Andrew
- Tyrell Corp
- Thank you received: 261
06 Jun 2017 06:02 #763708
by Tyrell Corp
Replied by Tyrell Corp on topic Doozie of a starter problem.
Get a couple of jump leads batt - ve to engine groundpoint batt + to starter + terminal. You are eliminating the solenoid and leads and testing just the starter.
You can energise the solenoid, it will click when connected. Starter button / kill switch and interconnecting wiring and block connectors would be worth looking at.
This Neutral / Clutch / stand interlock is a simple logic circuit and will disable the starter if any or all of the three conditions are not met. This is easily disconntected.
- Racewayelko
16 Jun 2017 05:38 #764501
by Racewayelko
Replied by Racewayelko on topic Doozie of a starter problem.
Sorry for the delay in getting back to you, you were right, it was a loose connection in the wiring harness. THank you!
