Kz750 twin ignition coil wiring
- Backwoods_biker
05 Jun 2017 16:35
Alright I was wondering do the ignition coils on a 82 kz750 twin need constant power or do I need to put a relay in between??? Any help would be great
Re: Kz750 twin ignition coil wiring
07 Jun 2017 22:55Backwoods_biker wrote: Alright I was wondering do the ignition coils on a 82 kz750 twin need constant power or do I need to put a relay in between??? Any help would be great
The stock KZ750 twin has only one dual output ignition coil. The single coil has two high tension spark plug wires coming out of it.
08 Jun 2017 04:22
No relay needed unless there is a problem with the wiring, in which case the wiring should be fixed.
