KZ650 Running Lights
  • biker_smith
  • biker_smith's Avatar Topic Author
05 Jun 2017 01:28
#763567
Hi all,
On my refurbishment of a KZ650 E1 LTD 1980 - when the ignition is on the lights are on - I get that since its a US and Canada bike only. But the front indicators are also on but not flashing.
Is that a standard feature of the bike for safety?
Thanks Paul.
Attachment not found
  • martin_csr
  • martin_csr's Avatar
Re: KZ650 Running Lights
05 Jun 2017 05:26 - 05 Jun 2017 05:27
#763572
The front turn signals also serve as running lights & hazards. The Fr turn signals are 2-wire plus each one has a ground wire.
The Fr turn signal bulbs have 2 filaments --- one for the running lights & one for the turn signals.
Ignition switch on -->> running lights on (but not flashing).
Turn signal on -->> running lights stay on & the bulb brightens as the turn signal filament flashes.
Hazards -->> same thing as turn signals, but of course all 4 turn signals flash at the same time.
Last edit: 05 Jun 2017 05:27 by martin_csr.
The following user(s) said Thank You: biker_smith
  • biker_smith
05 Jun 2017 05:58
#763575
Martin,
Thanks for that confirmation.
I've disconnected the front running lights as it could be confusing for UK drivers as they may think I'm indicating to turn.
Regards - Paul.
  • ezrider714
  • ezrider714's Avatar
05 Jun 2017 19:45
#763687
Just for information This isn't the normal configuration for turn signals in the UK ?? Cars do not operate that way?? From the front there is no lights but the headlight??
If all this is correct it amazes me, seems decades behind safety wise and can't believe I've never read about it....... Crazy
EZ
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
05 Jun 2017 20:36
#763694
The UK law is pretty strange and seems to reduce rather than enhance the bike's visibility! I may be wrong, but believe the problem stems from their "Direction Indicators" requirement that states:
"Amber lamps located within the indicator lamp must not adversely affect the operation of the indicator i.e. the indicator must go on and off to function not dim and bright."
That wording which would in theory preclude front running lights from staying lighted when turn signals flash is shown in the link below. Very strange. Ed
www.motuk.com/bike/1-5.asp#Menu_Top
  • martin_csr
06 Jun 2017 05:04 - 06 Jun 2017 05:05
#763702
Which then brings up the question, why aren't there rear running lights in the USA?
Last edit: 06 Jun 2017 05:05 by martin_csr.
  • Tyrell Corp
  • Tyrell Corp's Avatar
06 Jun 2017 05:53
#763707
Disagree, we call indicators 'winkers' here for a reason. This is a convention any UK or EU motorist would know and expect. US style signalling used here would just create confusion.
