83 KZ550 LTD oil light
  • jdvorchak
  • jdvorchak's Avatar Topic Author
31 May 2017 22:22
#763214
On my new to me 83 KZ550 Shaft drive the oil light comes on for about 3 seconds after you turn the key on and then goes out. Exactly like the Fuel light. Now I'm talking without trying to start. Just Ignition on. Is that normal? Doesn't sound very useful if it is.
Thanks in advance.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • Nessism
  • Nessism's Avatar
  • Away
Re: 83 KZ550 LTD oil light
01 Jun 2017 05:39
#763222
Some research is in order. Sounds like your bike has an oil level sensor, not an oil pressure sensor. A number of KZ bikes had that feature. Look for a round sensor on the bottom of your oil pan that attaches with two screws. If you find one that's the oil level sensor.
The following user(s) said Thank You: jdvorchak
  • martin_csr
  • martin_csr's Avatar
01 Jun 2017 08:09 - 01 Jun 2017 08:46
#763237
Good catch. It should have an oil level switch.
My guess is that the warning light should come on for a few seconds when the ignition switch is turned on, but then turn off.
Do you have the owner's manual for the motorcycle? It should explain the functionality of the oil warning light.
The 750-4 service manual explains how to test the oil level switch, but these have an LCD display.
One test is to make sure the oil level is correct, using the oil level gauge.
Last edit: 01 Jun 2017 08:46 by martin_csr.
  • loudhvx
  • loudhvx's Avatar
01 Jun 2017 09:39
#763243
As Martin and Ed said, the later 550's had oil level sensors. The early 550's had oil pressure sensors.
  • jdvorchak
02 Jun 2017 04:20
#763295
I changed the oil and filter yesterday and yes right next to the oil drain plug is a round sensor held on with two screws.
I don't have the owners manual but I do have the service manual. I'll see if I can read about it. The bike does have a sight glass so in my mind I'd rather have a pressure light but I guess the engineers felt that their oil pumps and bypass on the filter was reliable enough.
Thank you Ed and all that replied.
John
83 KZ550M1
83 KZ1100LTD
Also own:
  • martin_csr
02 Jun 2017 08:43 - 02 Jun 2017 08:45
#763331
I would consider installing an oil pressure switch. not sure how simple this would be. I did a quick comparison of oil pan photos on eebbaayy, and the 550C looks kind of similar. From the cross-reference at partzilla they use the same gasket, so maybe a chain drive oil pan can be used. ??? ... The wiring for an oil pressure switch should be pretty simple.
Last edit: 02 Jun 2017 08:45 by martin_csr.
