Connecting handlebar switches to M Unit
  • jkdowd
  • jkdowd's Avatar Topic Author
31 May 2017 07:36
#763149
Help from somebody who has used an M Unit with Switch style controls!
I am attaching a picture of the wiring guide that came with the hand controls I put on my KZ.
I connected the high beam and low beam wires together and put them into the light input on the M Unit, I put each of the left and right turn signals into their input, the the horn into the horn Input.
For some reason, neither the turn signals or head light switches are working, but the horn switch does work. I assume it's because I haven't connected the "headlight main" and turn signal relay wires anywhere. Where should I run the headlight main wire and the turn signal relay wire since the M Unit is my relay?
