dyna s ignition
- matlock
dyna s ignition
30 May 2017 15:20
alright guys i have a 82 kz750 spectre i have been working on for a long time now I recently purchased a dyna s ignition system kit that came with new coils and everything. my question is does this system replace the ignitor and how exactly do i wire it up? any help or links to some videos would be greatly appreciated.
Re: dyna s ignition
30 May 2017 15:55
Instructions.
- loudhvx
Re: dyna s ignition
30 May 2017 17:19 - 30 May 2017 17:20
The Dyna S replaces the igniter and pickups all as one unit, but don't throw away the old ones. The original system was more efficient and statistically more reliable. Someone somewhere wants them.
Also, you do know the Dyna S will require you to get new coils, correct? The instructions, in Steve's link, specifies the Dyna S must be used with coils that are 3.0 ohms or higher. The original factory coils would have been somewhere between 2.3 ohms and 2.6 ohms.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 30 May 2017 17:20 by loudhvx.
Re: dyna s ignition
30 May 2017 18:21
Good catch.
- matlock
Re: dyna s ignition
30 May 2017 20:10
Thanks guys. Yea it came with new coils as well. I've heard mixed reviews about it now that I have purchased it... but I still have the old one so if it doesn't work well ill swap it back out...
Re: dyna s ignition
31 May 2017 05:51
Just an FYI. You can use the green Dyna 3.0 ohm coils with the stock ignition system. The stock coils are probably the weak link the the Kawasaki ignition. I installed the green Dynas on my 81 650 which has the same ignition system as most if not all 750-4 models.
