Turn signals not flashing
  • Kz250 enthusiast
  • Kz250 enthusiast's Avatar Topic Author
28 May 2017 18:02
#762989
I have a problem with my turn signals not flashing. When I turn the indicators on the lights will turn on but not flash. This happens to all of them left right front and back. I checked all the bulbs and replaced the flasher relay with a new one and the problem stayed the same. What should I be testing next?
Re: Turn signals not flashing
28 May 2017 19:10
#762990
Is your battery fully charged? When my battery was not fully charged the stock relay wouldn't make the blinkers flash. A fully charged battery helped, but what totally solved the problem was replacing the stock flasher relay with a modern electronic unit (about $9). The electronic units do not require a fully charged battery to make the blinkers flash. Ed
