No match for stator-magneto combo!
  • Apets1100
  • Apets1100's Avatar Topic Author
Re: No match for stator-magneto combo!
21 May 2017 05:26
#762365
Loudhvx thank you, I think you got a point with the extra power needed.. I'm pretty sure that my new stator is wrong.
I've got measurements of the rotor, but they are at the repair Shop. I can post them here in case that somebody can help
Tony
GP1100z B2
  • Apets1100
21 May 2017 14:22
#762398
My rotor's measurements:
129 mm outside diameter
106 mm inside diameter
45 mm outside depth
Tony
GP1100z B2
  • Apets1100
27 May 2017 13:40
#762885
Hi guys,
Reporting:The new R/R is on the bike, overcharging problem solved.
So, now i have a new stator which i can't use because it's for a different bike.
It's not useful to me, somebody else could use it but i have to know which bike it fits somehow..
Can I post measurements and maby somebody could identify it?
Tony
GP1100z B2
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 May 2017 15:51
#762905
Glad to hear it. Yes, post it, maybe someone else can use it.
  • Apets1100
31 Aug 2017 00:08
#770045
Sorry for the delay, that was a very busy summer..
I have the dimensions for the unneeded stator of mine:
bolt holes, center to center: 38mm
inside diameter: 35mm
outside diameter: 93mm
stator width:23mm
Tony
GP1100z B2
  • PLUMMEN
  • PLUMMEN's Avatar
01 Sep 2017 05:10
#770133
If its,for your z1/kz I'm pretty sure 73-78 900/1000 use same parts.
79-80 1000 used the newer style,I don't remember if they will fit the older crank
Although the 79 1000 Ltd still used a small pin crank,not sure if end of crank is same though.
