KZ750 simplified wiring
- JusTrynaRide
09 May 2017 19:36
Im currently working on my dads 81' kz750 and the wiring harness is in pretty bad shape so i decided to try and wire it my self. Im trying to do so with only the essential components and cut out as much as possible but i dont know much about what i can bypass if anything or how to do so
Re: KZ750 simplified wiring
10 May 2017 05:30 - 10 May 2017 05:31
How bad is the wire harness? Are there just missing connectors or is it hacked everywhere or what?
Instead of rebuilding a new harness, you might be able to find a good used harness on eebbaayy.
If you go ahead & make one, CycleTerminal.com has terminal pins & connectors and open barrel crimper & pin extractor tools.
Z1Enterprises.com has electrical stuff as well & they have colored wire.
bare bones for mattylight ... various simplified wiring diagrams. see pages 11-20.
note: some of the wiring diagrams are no longer there (pgs. 1-10).
Last edit: 10 May 2017 05:31 by martin_csr.
The following user(s) said Thank You: JusTrynaRide
- JusTrynaRide
14 May 2017 16:34
It has many connectors melted or missing, im looking at just buying one off eebbaayy but i appreciate the links for parts
