First Post IC Igniter Compatibility
  • retka
  • retka's Avatar Topic Author
21 Apr 2017 10:49 - 21 Apr 2017 11:00
#759787
No eBay APP ID and/or Cert ID defined in Kunena configurationI just recently purchased a new igniter (21119-1040) for my 81 650 CSR, but is showing signs of a possible short in one of the wires, which is causing the entire engine to cutout when moving the igniter around by hand. I'm hoping to just go ahead and buy another igniter rather than go through the entire trip and cost of moving to Dyna S, since everything works as stock perfectly (and bike is very low mileage).
I've seen several new manufactured IC igniters such as from caltric, as well as some "similar looking" IC igniters with different model numbers (such as 21119-1020). I'm wondering if I can use one of these other igniters besides the 1040 item such as the one on the kz1100? I've got the mechanical advancer underneath by the engine.
Example:
Also, does anyone still have a copy of the GM DIY igniter? All of the old links are dead. Thanks!
1981 KZ650H1 CSR - sold
1981 KZ305 CSR (current)
Virginia
Last edit: 21 Apr 2017 11:00 by retka.
  • loudhvx
  • loudhvx's Avatar
Re: IC Igniter Compatibility
21 Apr 2017 17:47 - 21 Apr 2017 18:33
#759849
As long as it looks like the one in your photo, it should be swappable. Different part numbers may just be for different length wires. As long as you can splice wires, it should work.
I have a link to the GM version in my signature links. But be aware, the GM ignition modules are being designed differently now. You have to use the older type that was very common about 10 years ago. Details on how to tell the difference is also linked to from the GM project page.
EDIT: It looks like amazon web service is down, or being uncooperative. I had to reconfigure the links for some reason.
s3.amazonaws.com/gpzweb/Ignition/GPZgmHEImod.html
Last edit: 21 Apr 2017 18:33 by loudhvx.
The following user(s) said Thank You: retka
  • retka
21 Apr 2017 19:59
#759861
Perfect. The link and info is appreciated!
Virginia
  • Withintheruins26
  • Withintheruins26's Avatar
23 Nov 2019 17:19
#814421
Is there a way to make this diy igniter for a single coil single cylinder?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Nov 2019 21:20
#814431
For single coil and cylinder igniter use the diagram for a KZ 750 twin Version.
  • loudhvx
  • loudhvx's Avatar
23 Nov 2019 21:33
#814433
It will not work on a 1981 Kz250D2 CSR. That bike uses electronic-advance, and may actually be a CDI..
  • Withintheruins26
24 Nov 2019 05:24
#814442
I tried using a cdi not sure if it supposed to be dc or ac considering it’s full electric start with no kicker. But the stator and trigger aren’t wired together like a normal modern electronic system. And it’s throwing me off. I posted a topic about it and needing help. Lol and how the stator only has 2 yellow wires and a neutral switch wire, and the trigger has a green and red wire.
  • Nessism
  • Nessism's Avatar
24 Nov 2019 11:34
#814470
There are scads of different bikes that use the same ignitor (see below.) I'd be leary of purchasing an aftermarket ignitor unless someone else has gineypiged it first.
BTW, your bike uses the same ignitor as mine. I'll be glad to test yours on my bike if you want to perform a sanity check.
This Kawasaki 21119-1040 IGNITER Not Available fits the following models and components:
Kawasaki Motorcycle 1983 Spectre - KZ550-F1 Ignition
Kawasaki Motorcycle 1981 GPz - KZ550-D1 Ignition
Kawasaki Motorcycle 1980 Classic - KZ1000-G1 Ignition
Kawasaki Motorcycle 1984 LTD Shaft - KZ550-F2 Ignition
Kawasaki Motorcycle 1983 LTD Shaft - KZ550-M1 Ignition
Kawasaki Motorcycle 1983 LTD - KZ750-H4 IGNITION ('80 H1)
Kawasaki Motorcycle 1980 LTD - KZ750-H1 IGNITION ('80 H1)
Kawasaki Motorcycle 1982 LTD - KZ750-H3 IGNITION ('80 H1)
Kawasaki Motorcycle 1981 LTD - KZ750-H2 IGNITION ('80 H1)
Kawasaki Motorcycle 1980 KZ750-E1 IGNITION ('80 KZY 50-E1)
Kawasaki Motorcycle 1981 KZ750-E2 IGNITION ('80 KZY 50-E1)
Kawasaki Motorcycle 1982 KZ750-E3 IGNITION ('80 KZY 50-E1)
Kawasaki Motorcycle 1981 KZ550-A2 IGNITION ('80-'81 A2/A3)
Kawasaki Motorcycle 1980 KZ550-A1 IGNITION ('80-'81 A2/A3)
Kawasaki Motorcycle 1982 KZ550-A3 IGNITION ('80-'81 A2/A3)
Kawasaki Motorcycle 1983 KZ550-A4 IGNITION ('80-'81 A2/A3)
Kawasaki Motorcycle 1980 LTD - KZ550-C1 IGNITION ('80-'81 C1/C2)
Kawasaki Motorcycle 1981 LTD - KZ550-C2 IGNITION ('80-'81 C1/C2)
Kawasaki Motorcycle 1983 LTD - KZ550-C4 IGNITION ('80-'81 C1/C2)
Kawasaki Motorcycle 1982 LTD - KZ550-C3 IGNITION ('80-'81 C1/C2)
Kawasaki Motorcycle 1981 KZ750-E2 IGNITION ('81 -'82 KZ750-E2/E3)
Kawasaki Motorcycle 1980 KZ750-E1 IGNITION ('81 -'82 KZ750-E2/E3)
Kawasaki Motorcycle 1982 KZ750-E3 IGNITION ('81 -'82 KZ750-E2/E3)
Kawasaki Motorcycle 1983 CSR - KZ650-H3 IGNITION ('81-'82 H1/H2)
Kawasaki Motorcycle 1982 CSR - KZ650-H2 IGNITION ('81-'82 H1/H2)
Kawasaki Motorcycle 1981 CSR - KZ650-H1 IGNITION ('81-'82 H1/H2)
Kawasaki Motorcycle 1982 LTD - KZ750-H3 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1980 LTD - KZ750-H1 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1983 LTD - KZ750-H4 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1981 LTD - KZ750-H2 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1982 KZ550-A3 IGNITION ('82-'83 A3/A4)
Kawasaki Motorcycle 1983 KZ550-A4 IGNITION ('82-'83 A3/A4)
Kawasaki Motorcycle 1980 KZ550-A1 IGNITION ('82-'83 A3/A4)
Kawasaki Motorcycle 1981 KZ550-A2 IGNITION ('82-'83 A3/A4)
Kawasaki Motorcycle 1980 LTD - KZ550-C1 IGNITION ('82-'83 C3/C4)
Kawasaki Motorcycle 1982 LTD - KZ550-C3 IGNITION ('82-'83 C3/C4)
Kawasaki Motorcycle 1983 LTD - KZ550-C4 IGNITION ('82-'83 C3/C4)
Kawasaki Motorcycle 1981 LTD - KZ550-C2 IGNITION ('82-'83 C3/C4)
The following user(s) said Thank You: commotoed
  • Withintheruins26
24 Nov 2019 12:34
#814472
But my bike is an 81 KZ250 Ltd csr
  • TexasKZ
  • TexasKZ's Avatar
24 Nov 2019 13:04 - 24 Nov 2019 13:06
#814473
Here is the fitment list for the igniter on the 250CSR
www.partzilla.com/product/kawasaki/21119...890aa805716d68b32f2d
Full list price for a new one is $510. Partzilla sells them for $395.
Last edit: 24 Nov 2019 13:06 by TexasKZ.
  • loudhvx
  • loudhvx's Avatar
24 Nov 2019 14:15 - 24 Nov 2019 14:17
#814481
As mentioned, his bike does not use the same system found on most larger Kz's. It's incompatible with those igniters.
But according to Texas's link, his bike uses one that is used on other 200's and 250's. So maybe he can score a used one from another model.
Last edit: 24 Nov 2019 14:17 by loudhvx.
The following user(s) said Thank You: Withintheruins26
  • Nessism
  • Nessism's Avatar
24 Nov 2019 14:22
#814482
My bad. Didn't recognize that we had a request inside someone else's thread. I saw the OP's signature mentioning '81 650 CSR and I thought that's what we were discussing. Never mind...
