Kz440 Help
  • Kz440build
  • Kz440build's Avatar Topic Author
Kz440 Help
07 Apr 2017 06:32
#758703
Hello everyone I have a 1980 kz440 with point and I want to convert it to the dyna system. Can someone please tell me what all I need and a link were I can buy it. Thank you.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Kz440 Help
07 Apr 2017 07:20
#758707
You can contact them directly and see if they can help you. I've bought parts from them and they're good people.
www.dynaonline.com/products/sportbikes/dyna-s.aspx
  • Kz440build
Re: Kz440 Help
07 Apr 2017 07:22
#758708
Ok thanks
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Kz440 Help
07 Apr 2017 07:48
#758712
Let us know what happens. I suspect you might be able to use a pickup and rotor on your plate with a little ingenuity if they don't have the set. Pic of your points setup/
Stev
  • diggerdanh
  • diggerdanh's Avatar
Re: Kz440 Help
07 Apr 2017 08:27
#758714
If they have one for the KZ750 twin it should also work on the KZ400/440. From what I remember the factory KZ440 electronic ignition can be retrofit to the KZ750 twin.
There was quite a bit about using the Dyna on the old KZ Twin Owners forum. I think that there was a lot of talk that the kit for the KZ650/750 could be modified to work with the KZ400/440, but I do not remember the details.
Another option is finding and using the factory bits from a KZ440 electronic ignition. They were fit like that from 82 on. They retrofit pretty easily to the earlier KZ400/440s. I have made that change to both my KZ400s.
The following user(s) said Thank You: Kz440build
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Kz440 Help
07 Apr 2017 17:36
#758746
The ignition plate from a KZ650/750 will bolt up.
But the rotor is not in the right place.
Also the rotor on the KZ650/750 will spin clockwise
and the KZ400/440 will spin counterclockwise.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: GPz550D1, Kz440build
