Voltage variation
  • SmokyOwl
  • SmokyOwl's Avatar Topic Author
Voltage variation
31 Mar 2017 23:16 - 31 Mar 2017 23:17
#758269
I've noticed that my headlight (and all other lights) tends to dim at idle, and noticeably brightens when throttling at any higher rpm. To be clear, the brightness stays constant whether at 2,000 rpm or 7,000 rpms, but when it's at idle (about 1,000 rpm) it is noticeably dimmer.
Would replacing my stator resolve this issue? Or could it just need battery replacement?
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
Last edit: 31 Mar 2017 23:17 by SmokyOwl.
  • martin_csr
  • martin_csr's Avatar
Re: Voltage variation
01 Apr 2017 04:29 - 02 Apr 2017 06:07
#758273
It could be the battery. How old is it, what type & do you keep it properly charged?
Have you done any voltage checks? After charging, it should be 12.6 VDC, but a good battery will be higher.
Poor connections or improperly sized headlight or bulbs are other things to check.
Last edit: 02 Apr 2017 06:07 by martin_csr.
  • Nessism
  • Nessism's Avatar
01 Apr 2017 04:45
#758275
What you describe is normal for the most part but I'd check the charging system. With the engine reved up to 5000 rpm there should be 14.5 volts or thereabouts across the battery. If you have less than 14 or more than 15 that indicates problems. Of course, check the battery too a martin says too.
  • Tyrell Corp
  • Tyrell Corp's Avatar
01 Apr 2017 05:31
#758281
The voltage will increase as rpms increase, that is normal but the difference in headlamp brightness is hardly noticeable.
Assuming your battery is even half decent then probably cleaning up all your electrical connections / battery clamps / frame earths would almost eliminate this. Your lights will be noticeably brighter too. Any 30 year old bike always benefits from this.
01 Apr 2017 17:17
#758308
From what I've seen with my KZ650-C1 over the past 40 years as long as the headlight isn't going too dim at idle what you describe is normal. I would not recommend replacing the stator. If the stator had a problem the lights wouldn't brighten up much when the engine revs above idle. Take a look at the Kawasaki Service Manual if you still think there's a problem. It has a section on how to test the charging system. Ed
  • SmokyOwl
05 Apr 2017 00:26
#758515
Thanks for the replies guys, looks like one less thing to worry about. I was planning on replacing the battery anyways, but good to know it's normal.
  • bountyhunter
  • bountyhunter's Avatar
06 Apr 2017 21:26
#758683
SmokyOwl wrote: I've noticed that my headlight (and all other lights) tends to dim at idle, and noticeably brightens when throttling at any higher rpm. To be clear, the brightness stays constant whether at 2,000 rpm or 7,000 rpms, but when it's at idle (about 1,000 rpm) it is noticeably dimmer.
That's normal. The system voltage drops to 12V at lower RPM and runs up to about 1`4V above 2k RPM.
The following user(s) said Thank You: GPz550D1, SmokyOwl
  • Barry2
  • Barry2's Avatar
06 Apr 2017 22:17
#758686
It also is a good idea to check the electrolyte level in the battery once in a while. If low be sure to use distilled water.
1976 KZ900
  • TexasKZ
  • TexasKZ's Avatar
08 Apr 2017 16:25
#758799
Barry2 wrote: It also is a good idea to check the electrolyte level in the battery once in a while. If low be sure to use distilled water.
Or get an AGM battery and forget the water.
  • SmokyOwl
08 Apr 2017 22:39 - 08 Apr 2017 22:45
#758813
Thanks for reminding me guys, I had been battling the internet for a couple hours yesterday trying to figure out what battery to buy for my old kawi.
I know the old-school distilled water chambers are tried-and-true for these old bikes, but I really can't find any discernable difference between any brands. Any brands to look at or stay clear of would be helpful. Does it really matter? Prices are eyebrow-raising low sometimes and makes me question quality of the batteries. A lot of odd brand names I've never heard of are everywhere.
Now I'm going to check out agm batteries, thanks TexasKZ.
.....and just to be certain....lithium batteries should not be installed in these old bikes right?
Last edit: 08 Apr 2017 22:45 by SmokyOwl.
  • TexasKZ
  • TexasKZ's Avatar
09 Apr 2017 05:15
#758820
You are right that there are quite a few good choices out there. I have had really good luck with Yuasa and Interstate. Both are readily available near me and I have gotten really good service from the dealer.
I think you are also right about the lithium batteries, unless you have upgraded to a more sophisticated regulator.
  • martin_csr
09 Apr 2017 07:28
#758825
Some of the Yuasa powersport batteries are made in USA, but I don't think they have an AGM for my bike.
I got a scorpion agm from batterystuff.com & it has proven to be an excellent battery so far. I also have a Ctek US 0.8 smart charger & VC97 digital multimeter.
