Ignition switch problems... with pictures
  • 2005jetta
  • 2005jetta's Avatar Topic Author
21 Mar 2017 17:50
#757344
Ok, so recently i picked up an 1984 zn1100 LTD. I have everything ready to go except I need a new ignition switch. Problem is, they apparently they no longer exist :( I have scoured ebay for 2 weeks, no dice on a new, or used unit. There is one that claims to fit, and i ordered it. However, it does NOT fit as claimed by the ebay seller. The ignition switch on my bike has a square brown plug. And they one they sent me, and the ones i see on ebay have a rectangle brown plug. They both have 7 wires... but the bodies are different size and it wouldn't mount up even if i did some wire hacking. Any ideas on what i can do? I searched pages of results on google and sent messages to many companies and sellers, with no luck. Really sucks to be stuck at this point, with no apparent fix in site. Thanks in advance.
  • mopguy
  • mopguy's Avatar
Re: Ignition switch problems... with pictures
21 Mar 2017 18:05 - 21 Mar 2017 18:18
#757345
Try here, I got these sites from a member here 650Ed
www.cycleterminal.com/250-connectors .
vintageconnections.com/
Last edit: 21 Mar 2017 18:18 by mopguy.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
25 Mar 2017 06:57
#757607
Is the original one salvageable?
Give me the key code, probably z5000~Z6000 #, and I'll cut you a key.
Rob
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • martin_csr
  • martin_csr's Avatar
25 Mar 2017 07:16 - 25 Mar 2017 07:26
#757609
I would return that ignition switch. It's obviously wrong & their x-ref is wrong.
The Vulcan 750 ign switch is similar, but I don't know if it will fit the ZN700. (Vulcan VN700 VN750). also the EN450
As for mismatched connectors, if the terminal pins are the same size, then you can easily swap connectors or get a new connector.
If you have to replace the terminal pins, get the correct type & use a ratcheting open barrel crimper. cycleterminal.com etc.
1986-2006 KAWASAKI VULCAN 750 VN750 IGNITION SWITCH WITH KEYS 27005-5052 NEW! .... Partzilla has it listed for $85 + sh.
Last edit: 25 Mar 2017 07:26 by martin_csr.
  • 2005jetta
04 Apr 2017 17:47
#758506
Hey guys sorry for the late response. What I ended up figuring out is that the only one that you can use in the place is for the zn 1300 Voyager. It's slightly longer in the cylinder part up top but mounts in perfectly and plugs up. Hopefully this post will help somebody else in the future. Thanks again!
  • martin_csr
05 Apr 2017 05:46 - 05 Apr 2017 05:52
#758521
Did you find a new aftermarket ignition switch or did you get one from a Voyager?
And how many wires does the ZN1100 ignition switch have? Thanks.
For future reference. The ZN700 & ZN1100 use the same ignition switch. Also, in Canada there was a ZN750 model & its ign switch is probably the same as the 700/1100. and as indicated above the vulcan 750 appears to be very similar & seems to have the same connector. here's a used one for comparison. VN750
Last edit: 05 Apr 2017 05:52 by martin_csr.
  • 2005jetta
05 Apr 2017 19:37
#758587
I bought a used ignition switch from a zn1300 voyager. I got it on ebay for 27$ free shipping... I think i got very lucky lol. Good to know zn700 parts my work for things i need as well. Since parts can be pretty hard to find for these zn1100's. The zn1100 has 7 wires running to a square 9 prong plug that is brown in color. 3 rows of 3. The cylinder where the key goes is about 3/4 of an inch taller then my original. Thank you for your help man!
  • martin_csr
06 Apr 2017 05:56
#758606
Thanks for the info --- it might help someone else down the line. The ZN700 & ZN1100 share some stuff. I'm pretty sure the meters, wheels & fenders are the same as well as the tail light & tail cover, but I believe the seat, tank & side covers are different.
  • cb900f
  • cb900f's Avatar
01 Nov 2021 01:05
#857247
Reviving this old post....
Do any of you guys know if the ignition switches mentioned here (ZN700//1100/1300, etc.) can be disassembled to clean the internal electrical contacts?
