Trouble starting when hot
  • IOC750
  • IOC750's Avatar Topic Author
21 Mar 2017 07:20
#757302
My bike fires up great in the morning, actually any time of day. Once I get to work and try to start it again, the engine doesn't turn over, as though the battery is dead. If I come back a few hours later, it starts again. I'm at a loss here.
A few points of reference:
  • The battery is brand new. The previous battery was also new - I replaced it due to thinking it was the issue
  • The reg/rec is doing its job, output is 14.5V while revving - tested right after starting and after a ride
  • Sometimes though the battery is dead from the start, I'm not sure whether that is only after trying to engage the starter after the engine is hot
Could something be drawing so much power that it drains the battery? Would that not blow a fuse?
I made the fuse box myself, it was missing when I bought the bike. I'm sure it is good though as I followed the wiring diagram.
Cheers
1980 KZ750 H1
All the way in Africa
  • diggerdanh
  • diggerdanh's Avatar
Re: Trouble starting when hot
21 Mar 2017 12:56 - 21 Mar 2017 13:00
#757326
IOC750 wrote: the engine doesn't turn over, as though the battery is dead. If I come back a few hours later, it starts again..
Are you putting a battery charger on it in the time between?
Something could be drawing enough power to drain the battery ( for example high power headlight, other additional lighting added, heated grips ) faster than the charging system can keep up but I cannot imagine that it would be better later without putting a charger on the battery. A parasitic draw wouldn't blow a fuse.
Can you hear the solenoid clicking when you try to start it but it won't?
Last edit: 21 Mar 2017 13:00 by diggerdanh.
  • diggerdanh
21 Mar 2017 13:06
#757327
Take a multimeter with you on one of your morning rides and test the battery when it acts like this. That ought to tell you if the battery is charging properly or draining. If it still measure okay you can rule out the charging system and look at other areas.
21 Mar 2017 13:09
#757328
Is it possible that the pistons or rings are binding when the engine is hot and the electric starter doesn’t have enough oomph to spin the engine? I would try the following to make sure that isn’t a problem – run the bike until it is totally warmed up then use a wrench on the crankshaft (under the ignition engine cover) to see if the engine will turn over without unusual effort. You can first try turning it over when cold to see how much resistance is normal.
Also, you could try checking the battery voltage when the engine is hot, but I suspect that’s not going to show low battery voltage with no load on it. Ed
The following user(s) said Thank You: GPz550D1, IOC750
  • IOC750
21 Mar 2017 14:31 - 21 Mar 2017 14:33
#757332
No I don't have a charger hooked up after, though after a few days the battery needs charge.
Edit: And yes, it isn't completely dead, I can hear it trying to engage. Headlight and turn signals still work after these encounters
650ed wrote: Is it possible that the pistons or rings are binding when the engine is hot and the electric starter doesn’t have enough oomph to spin the engine? I would try the following to make sure that isn’t a problem – run the bike until it is totally warmed up then use a wrench on the crankshaft (under the ignition engine cover) to see if the engine will turn over without unusual effort. You can first try turning it over when cold to see how much resistance is normal.
Thanks Ed, I'll definitely give that a shot tomorrow (it's nearly midnight here)
Cheers
1980 KZ750 H1
Last edit: 21 Mar 2017 14:33 by IOC750. Reason: Unanswered questions
  • JR
  • JR's Avatar
21 Mar 2017 17:39
#757341
Friend of mine had a similar problem in a Honda .......so maybe that doesnt count :laugh:
Hi bike would start fine first ride of the day and then parking for 30 - 60 minutes and coming back to the bike the engine wouldnt even turn over when he hit the starter button. He used to park on a hill and bump start. Turned out to be the starter motor.
If everything else checks out then it mighbe worthwhile removing the starter motor and cleaning up the innards.
  • spdygon
  • spdygon's Avatar
21 Mar 2017 18:05
#757346
Some how connect a meter to the battery and strap the meter to the bars and take a ride....looking at the #'s
If ok could be the starter getting hot and won't spin afterwards.
How many miles on the bike?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • IOC750
21 Mar 2017 23:11
#757372
spdygon wrote: Some how connect a meter to the battery and strap the meter to the bars and take a ride....looking at the #'s
The odo is somewhere at around 43 000km
This morning when I tried to start it, the engine turned over a few times and then the battery was tired. It's at home on a trickle charger now.
Wouldn't the starter motor only get hot if the starter clutch wasn't properly disengaging? I'm really hoping I won't have to dig that deep.
I've still yet to try Ed's test of manual engine turnover, I was hoping to do that at work today.
Cheers
1980 KZ750 H1
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
21 Mar 2017 23:33
#757373
Hello
IMO the starter motor has a thermal problem (bearings / brushes to commutator).
when cold all tolerances are in spec but when hot some parts expand and cause more mechanical friction or electrical resistance.
Michael
  • Barry2
  • Barry2's Avatar
21 Mar 2017 23:44
#757374
I'm with Sirocco on this.
1976 KZ900
  • IOC750
22 Mar 2017 01:12
#757380
Scirocco wrote: Hello
Michael
Thanks a lot, I'll take it out and have a look. I wouldn't be surprised if the brushes are worn with carbon all over the place, this machine was riding before I was born :)
Cheers
1980 KZ750 H1
  • IOC750
29 Mar 2017 00:21
#758001
Just thought I'd update you lot and leave some information for future reference.
I took the starter motor out and gave it a quick clean (I was at work and didn't want to be without transport at day's end) so at some stage I'll do this properly. While under the cover, I noticed that one of the three cables coming from the alternator had a dry joint. The lugs still have the factory heat shrinking on it, which has become brittle.
After properly inserting the lug, it seems my charging issues are gone.
The important info here, is that it seems that your reg/rec and battery will still give you a 14.5V reading at 4000rpm even though the reg/rec is only being fed 2 phase power instead of the full 3. If anyone has a different experience with this, please chime in, this is just what I have observed.
2 phase alternator input is definitely not enough to keep everything going.
Thanks all for your input.
Cheers
1980 KZ750 H1
The following user(s) said Thank You: JR
