reg ??s help!!!
- steveo_4192003
- 77kz650b-1
reg ??s help!!!
09 Jul 2006 13:26
how many volts should come out the rectifier when its running? im getting around 1.5 to 2 volt ,and thats running!! bike dies after 20 min of riding!! dead battery!!
but i see my reg/cover may be on wrong!! (backwards)
i think i have the brn wire and ground switched around!
pwer/=brn goes to switch in reg, bottom terminal
green/=green goes to center terminal
black/=black to ground, top terminal
is this right?
my legend
yellow circle is a switch)
red circle is ground)
and green is from alt/charger in center)
Post edited by: steveo_4192003, at: 2006/07/09 19:31
Post edited by: steveo_4192003, at: 2006/07/09 19:38
Post edited by: steveo_4192003, at: 2006/07/09 20:12
Post edited by: steveo_4192003, at: 2006/07/09 20:13
is this right?
my legend
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- loudhvx
Re: reg ??s help!!!
10 Jul 2006 10:48
I don't know what the order of the colors was, but there should be color rectangles on the unit which tell you which colors go where.
2 volts is not enough out of the rectifier. I would hold off on doing anything until someone with a 77 650 can determine the connections for you.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- steveo_4192003
- 77kz650b-1
Re: reg ??s help! solved!
10 Jul 2006 11:39
i found my problem!!
the person i got bike from said the old battery wouldnt hold a charge, and my new one went dead also!!
i saw that the color blocks on reg /cover were on opposite side of the three tabs!!
i switched the cover around put the wires on agian and presto! the brown wire went straight to ground!
i have rode all day and still at 12.5 volt on battery
thanks all,for your help
- mariozappa
Re: reg ??s help!!!
10 Jul 2006 11:39
Too bad I didn't ride to work today or I would have gone out and popped the sidecover and looked.
I'll check when I get home tonight.
I think the brown goes on top, but don't quote me on that until I get back to you!
1977 KZ650C1
and the KZ650/KZ750 Conversion
- mariozappa
Re: reg ??s help!!!
10 Jul 2006 11:40
haha, good man!
1977 KZ650C1
