What load resistor for LED taillight???
- BOOM_FIST
19 Feb 2017 17:00
For you guys running LED taillights, what load resistor are you guys running?
I thought it would be a straight swap, but apparently not. I thought something was wrong with my wiring, but I plugged the stock incandescent bulb back up and it works as it should. So, all the wiring is good.
Any help would be awesome!
1977 KZ900A5
- loudhvx
Re: What load resistor for LED taillight???
19 Feb 2017 17:23
A 12v LED taillight bulb/assembly (designed to be used on vehicles) does not need any load resistor.
Sometimes load resistors are needed for turn signal flashers to work correctly, albeit by wasting power. A far better solution, for that is to use a fully electronic flasher. But none of that applies to a simple tail/brake light.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- BOOM_FIST
19 Feb 2017 17:28
That's what I thought, but I wasn't 100% positive with motorcycles. It's definitely a 12v LED taillight.
Any other ideas why it's not working??
1977 KZ900A5
- Nerdy
20 Feb 2017 06:35BOOM_FIST wrote: That's what I thought, but I wasn't 100% positive with motorcycles. It's definitely a 12v LED taillight.
If it's a new item, it's possible there was a manufacturing defect (which should have been caught in QA/QC) or it was damaged in shipping.
It's not one of those "self-grounding" lights is it? If so, you may need to remove some paint wherever it bolts up to the frame. If there's paint in the way you won't get a ground and the light won't work.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- BOOM_FIST
20 Feb 2017 07:50
Spent the better part of an hour last night troubleshooting and digging through the wiring diagrams again.
The RED and BLUE wires were opposite in the wiring. Got it all working finally and I was able to fab up a mounting bracket to eliminate the stock rear fender.
1977 KZ900A5
