I broke my speedo
- DGA
I broke my speedo
19 Feb 2017 12:42
Hi, the bike, '83 KZ1100 Spectre. I had complained on here awhile ago about the speedo having a bouncy needle. I noticed when I wheeled the bike along I could hear the cable or speedo guts making a scraping sound that matched the needle bounce. I sprayed thin grease up into the speedo drive and into the cable end, this helped it some for awhile. Well last night I had to go on a longer freeway trip so I pegged the needle at it's dumb 85 mph limit for over 15 mins, was over 6000 rpm so I think that was around 100 mph. On the trip back the needle started bouncing even more to the point I couldn't read it. Well today it just quit reading anything, stuck at zero. So, best way to get it apart, do I have to uncrimp the outer metal band or?
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
Re: I broke my speedo
19 Feb 2017 16:11
Are you sure it is not a broken cable?
19 Feb 2017 16:59
I'll bet it's the cable.
- DGA
19 Feb 2017 17:46
No it's not the cable, which is almost new and oiled.
Under further inspection, the needle jumped over the max speed limit post, so now is stuck under the zero speed post, under the back of it. Stupid 85 mph speedo. I would really like a 150 mph guts to this speedo, then this wouldn't happen again. Ok, I could keep the speed under 85, but that's not gonna happen anytime soon. Anyone know if I can transplant a 150 speedo internals into this Spectre housing?
19 Feb 2017 17:56
I was shopping for donor gauges. Pics?
kzrider.com/forum/5-chassis/599906-new-tach-speedo?start=120
- azman857
19 Feb 2017 19:58
Maybe consider aftermarket speedo? GPS or electronic?
- aek
19 Feb 2017 22:49
Problems I've had over the past 77000 miles has always involved the angle drive. I believe that as the unit wears the worm gear tries to climb the bevel gear creating the jumpiness you see in the needle. In my case at least replacing the drive unit restored the needle to dead steady. ymmv.
Regards,
Art
Regards,
Art
1980 750-4 LTD original owner
- DGA
20 Feb 2017 14:39
Thanks for all. I will attempt to pull it apart, it's dead as is like this so no loss if I can't fix it.
Steve, in the other post you linked to, did you find the difference with the 85 and the 160 mph speedos was just spring tension? If that was the case, I found new 160 faces I think, and could just add that and change the spring and do a general rehab inside and hope that works.
20 Feb 2017 15:07
Post a pic of what you have before you do anything.
- DGA
20 Feb 2017 19:58Here you go Steve. Might be a bit of a problem as it has the neutral and high beam lights in it? I will pull it apart in the next night or two.
20 Feb 2017 20:51
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
