Small DIY LifeP04 Battery For Kick Start Only
  • Hemp
  • Hemp's Avatar Topic Author
13 Jan 2017 15:42 - 13 Jan 2017 15:43
#752145
Hi folks.
I'm deep into a café-ish build on a 1980 750 twin and trying to finalize my battery design. I'm opting for a kick start only bike with a smaller battery rather than capacitor. There's chatter about some people using smaller scooter batteries, but I'm considering small lithium battery pack. There's lots of good small lithium packs available but I'm trying to wrap my head around the charging system to see if they are compatible. My questions are...
For a kick start only, does the battery have to have rated output amperage equal total system load(lights, ignition etc) or only enough output to energize the ignition during start up? In other words once the bike is started will the R/R and stator handle the operating load?
If the smaller battery can only be charged safely at a couple amps will the R/R prevent too much current from charging the battery? Lithium packs usually have built in protections that disconnect over a certain amount of charging amps. My fear is at higher rpms(amps) a smaller lithium battery's built in protection(2-5 amp cutoff) will disconnect from the charging system and the battery will get depleted under load while not charging.
Any thoughts?
Last edit: 13 Jan 2017 15:43 by Hemp.
  • loudhvx
  • loudhvx's Avatar
Re: Small DIY LifeP04 Battery For Kick Start Only
14 Jan 2017 12:56
#752190
Hemp wrote: Hi folks.
Any thoughts?
The excited field type charging systems usually tend to have a higher output available than the permanent magnet charging systems. This is because they are regulated in such a way that they only put out as much as the bike needs, thus the output of the alternator is regulated. The permanent magnet type alternator, like what I think is on your bike ('80 750 twin) is often made to put out about as much as the bike will need. This is because the regulator has the task of getting rid of the extra power that the alternator creates. This results in a lot of heat dissipation, and also needlessly robs excess power from the crankshaft, so they don't want the alternator to be too powerful.
The permanent magnet alternator should be powerful enough to power the bike, even at idle, albeit at a lower than optimum voltage. The 3-phase alternators tend to be able to put out more power than the 1-phase alternators.
The battery has two purposes. It provides power when the bike is not running, or idling slowly, and it acts like a capacitor to smooth out the power pulses coming from the charging system. The pulses must be smoothed out in order for the regulator to work properly. If there is too much pulsing, the regulator will tend to cause over-charging. In extreme cases, such as if the battery becomes disconnected while going down the highway, the voltage has been known to get so high it melts the light bulbs and burns out other components.
So the real question is whether the battery you are using has enough capacity to smooth out the pulses. Power-wise, it's not really an issue since capacitor have no real power storage compared to a battery, and most/all permanent-magnet KZ's can go batteryless with a capacitor.
The only way to know for sure is to measure the true RMS voltage on the battery during high output times. A typical voltmeter only measures average, and the regulator only regulates to average voltage. But pulsing DC has much higher RMS voltage, and that is what does the damage.
The following user(s) said Thank You: Patton
  • Hemp
15 Jan 2017 10:51
#752249
Wow loudhvx, That's about as detailed as responses get. Thank you for your time and information. It looks like I've been thinking of the R/R the wrong way. I always thought the R/R was 'up stream' the battery and acted as the buffer insuring the battery always got correct charging voltage, hence my original concern about amps and not voltage. But you're saying the battery works as a buffer for the R/R... correct? If s this changes things.
The BMS PCB board on the lithium battery I'm considering (below link) disconnects at around 17 volts. So in theory it might protect the bike's system from over voltage. Lead acid batteries don't have built in BMS PCB protection boards like lithium packs. I assume lead acid batteries absorb these peak volts while the lithium pack simply shunts off and severs connection. This means the battery might disconnect from the charging current because of too much amps and or volts. This takes me back to my original concern of the battery not getting charging current while supplying system load. Looks like I have more factors to consider.
www.all-battery.com/li-ion18650148v2200m...nlxNECFRKSfgodx1IJNA
  • loudhvx
  • loudhvx's Avatar
15 Jan 2017 13:26 - 15 Jan 2017 13:28
#752258
On your bike, the regulator acts on the AC side of the rectifier. It shorts out (aka shunts) the AC pulses to ground as necessary. Any un-shunted pulses go through the rectifier and act as a pulse of current to the system (battery and bike devices).
How big is the battery pack? Is it designed to actually start a small motorcycle or scooter? If so, it's probably big enough to use.
But I'm not sure about the disconnection behavior of it. 17v seems like a pretty high set-point for disconnection, but I'm not familiar with lithium batteries.
Bottom line, make sure your charging system is working perfectly before going to the lithium battery. That means make sure all of the connections, especially in the fuse area, are clean and good. Make sure there is no big voltage drop between the battery and regulator. As that can result in overcharging, which I think is a bigger concern with lithium. Make sure the highest charging voltage on the battery is around 14.5v, preferably closer to 14.2 or 14.3v.
Last edit: 15 Jan 2017 13:28 by loudhvx.
