1982 Kz550 rectifier wiring
  • alexromega
  • alexromega's Avatar Topic Author
  • first build and lovin it
07 Dec 2016 17:21
#749734
Could anyone tell me where I should put the brown wire coming out of my rectifier. They say it wires to the ignition switch but I'm sure how. The brown wire gets battery volotage, but not directly to the battery, right?
I'm wiring with the m unit and I think aftermarket regulator / rectifiers out there don't have a brown wire. I also have read that these model bikes need to have it Connect it to a 12V source. I Just need some more info on where I should wire this and how.
  • Nessism
  • Nessism's Avatar
Re: 1982 Kz550 rectifier wiring
07 Dec 2016 17:26
#749737
Brown is the sense wire. You are correct, it needs 12V, only from a switched source. If you decide to get a better R/R the Shindengen SH775 is much better than the typical chinese made shunt units. Search ebay for "polaris rzr regulator" and make sure you can see a photo showing the SH775 lettering on the top of the unit. These R/R's are a hot commodity and there are counterfeits on the market.
  • alexromega
07 Dec 2016 17:38
#749739
Thanks Nessism. I was trying to finish my wiring this weekend and just use the old. I've come to terms on buying a new one and just sticking it out lol. I also have a lithium 14 amp hour battery to charge. Yeah I'm gonna look for that before I buy.
  • loudhvx
  • loudhvx's Avatar
08 Dec 2016 08:14
#749765
If you follow the links in my sig, there are manuals and color diagrams which will show the brown wire. that wire connects to a lot of things on the bike.
