1982 KZ550A vs LTD Ignition Switch and Key
- BobbyKZ550
09 Nov 2016 07:55
Hey Guys/Gals (First Post)
Over the weekend i lost the only key I had to my 1982 KZ550 LTD and I have replace the ignition switch and minimum the key. The question I have is that i found a 1982 KZ550 ignition switch and key but it doesn't specify compatibility with LTD so Im hesitant to make the purchase.
Does anyone know if the KZ550A/Sport ignition switches are compatible with KZ550 LTD?
Or even better does anyone know of a website or store that has the capability of replacing just the key?
Any answers would be helpful.
Re: 1982 KZ550A vs LTD Ignition Switch and Key
09 Nov 2016 09:31 - 10 Nov 2016 05:25
From the diagrams at Partzilla the 550A & 550-Ltd have the same ignition switch but you should double-check the x-ref.
Replacement key. There should be a key code stamped on the ignition switch. the seat lock & helmet lock should be stamped with the same code. KZR topic w pic . KZR member rstnick might be able to make a key for you. A good locksmith should be able to make a key from the code. Also, there are keys available on eebbaayy.
Key blank that may work. Ilco KA14 X103
1 Kawasaki Motorcycle Keys Code Cut Z5601 thru Z5650 ATV- 4 Wheeler Key .... kinda pricy.
Last edit: 10 Nov 2016 05:25 by martin_csr.
- rrsmsw9999
09 Nov 2016 14:23
They are not Fort Knox lock cylinders, you could probable get any key blank the same dimensions and it would work without cutting. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rstnick
09 Nov 2016 16:20
Look for the Z series key code # (Z5001~Z6000), then see if someone local can make it.
Check ebay for an original, and if no luck, send me a message as I can cut them and mail it to you.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
09 Nov 2016 17:33
Any decent locksmith can make a key from the lock.
- BobbyKZ550
10 Nov 2016 09:59
I went ahead and called a locksmith and when he asked me for the key code I couldn't find it on the ignition (It seems really dull and worn so unless its somewhere else on the ignition switch I don't think I can get it cut again) and I had separate keys for the gas tank so I'm hesitant to use that code. I've had this bike for about two months (my first bike) and I never followed through with getting a duplicate before this happen so I'm back to square one.
Would anyone know if this linked ignition switch would be compatible? It says its for 1982 KZ550 Sports & Spectre but I have a 1982 KZ550 LTD. or where I could get one locally in Phx.
10 Nov 2016 13:56 - 11 Nov 2016 04:23
That ignition switch & part number look like something from the 70s, perhaps from a 650. I would find the correct part number at Partzilla or Kawasaki.com, then search eebbaayy to find a matching ignition switch. There's probably an emgo switch that looks the same as yours. Or try Z1Enterprises.com --- they probably have an Emgo.
Seat lock. Can you open the seat?
Last edit: 11 Nov 2016 04:23 by martin_csr.
- rstnick
10 Nov 2016 19:14
Check the seat lock for the Z code too.
Along the side or back.
Ignition too, side or back.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- loudhvx
11 Nov 2016 07:49 - 11 Nov 2016 07:52
The gas tank is not keyed. Any key should be able to open it on a 550, even a house key.
The seat lock and ignition should have been the same code if no one replaced it.
Like Martin said, the one in your link is not for a 550.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 11 Nov 2016 07:52 by loudhvx.
