Points Question
- OLJOCLARK
Points Question
23 Oct 2016 16:07
Anyone had any luck finding points at the Auto parts stores that will fit Kawasakies? 1980 750 LTD twin
1980 Kawasaki 750 ltd G Twin
Re: Points Question
23 Oct 2016 16:31
Never tried. You can clean up yours but the condencers could be shot. I've used Ford condencers wired upline next to the cois to get by.
The following user(s) said Thank You: OLJOCLARK
Re: Points Question
24 Oct 2016 06:51Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
Re: Points Question
24 Oct 2016 16:31
- OLJOCLARK
Re: Points Question
25 Oct 2016 14:29
Thanks folks,gonna try new points and condenser before I try a new coil.Been thru a lot still getting rich plugs,havent been able to tune it all in.got some on the way from ebay. I filed on em a lot to get the pits out,now I don't trust em,OLJO
- bluej58
Re: Points Question
26 Oct 2016 05:10
I don't use a file, I fold over a piece of 400 grit sand paper and work it back and forth between the closed set of points , then clean with acetone on heavy paper like a business card
78 KZ1000 A2A
