Not a KZ but it is a Kawasaki
  • AtLarge
  • AtLarge's Avatar Topic Author
19 Oct 2016 18:23 - 20 Oct 2016 04:45
#745705
Surely one of my KZ brothers has seen these two problems before.
Rehabbing my 75 Bighorn and have gone through carburetor, oil pump, etc. I am one step away from trying to fire it up. Before I turn on the gas and start kicking I have gone through all the electrics. Just about every plug, bullet connector, terminal ring, frame contact, and including the handlebar switches have been meticulously cleaned. I have a 6v 10A charger connected for power because I don't want to activate a new battery so late in the year if I don't get over this hurdle.
I have spark, running light, brake light (both switches), horn but no headlight or gauge lights. I tested the headlight and one gauge bulb independently and they work. Does the motor have to be running to complete the circuit?
With the ignition in the night time position, running tail light on, turn signal flashing, hit a brake switch (front or rear makes no difference) and the turn goes out and stops flashing. Brake light is nice and bright. Turn signals are too but hit the brake and they go out. What could be causing the brake light to stop the turn signals from flashing?
F5 Diagram
Any suggestions for me to go back and check would be appreciated because I am stumped. :(
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
Last edit: 20 Oct 2016 04:45 by AtLarge. Reason: Grammar error
  • Barry2
  • Barry2's Avatar
Re: Not a KZ but it is a Kawasaki
19 Oct 2016 22:38
#745723
In 1972 I bought a new 350 Kawi known as a model F9. In order to have a headlight and dash lights the engine had to be running.
the battery powered the neutral light, tail light and brake light with the engine not running..It was the last year they were not required to have turn signals so I can't help you with that part. OH.........And the horn would honk with the engine off too.
1976 KZ900
The following user(s) said Thank You: AtLarge
  • AtLarge
20 Oct 2016 05:13
#745729
Excellent! Thank you Barry2. That confirms my suspicion and solves half my tail chasing.
Now to figure out this turn signal / brake light issue. Just to clarify...
Daytime switched position, turn signals flash, apply brake, brake light goes on but signals stop flashing but are lit up.
Night time switched position, running light is on, turns flash but, cause the brake light to alternate on and off. When I hit a brake switch the brake light goes on but, the signals stop flashing and stay in lit mode.
This tells me it's grounding back through the system but, adding extra ground wires directly to the lines doesn't help. :huh:
1973 Honda CL70-K3
1994 BMW K1100RS
  • AtLarge
20 Oct 2016 16:44
#745776
Problem solved. PO used a 32w tail light bulb which is way too high. Fortunately, I had a 6v 17/5.3w on hand and that balanced it all out. Now the turn signals flash while the running and brake light are on. Yipppee! ;)
1973 Honda CL70-K3
1994 BMW K1100RS
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
21 Oct 2016 19:59
#745875
Heres me riding my Pops around on his 75 F9. He sold it at a yard sale for $50 back in the 80s. Prob had 2k miles on it. Ive been leisurly looking for one.
Attachment 10398582_1046768807005_994792_n.jpg not found
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • AtLarge
21 Oct 2016 20:18
#745876
Great shot! Bet that brings back memories.
1973 Honda CL70-K3
1994 BMW K1100RS
  • 80B4
  • 80B4's Avatar
10 Nov 2016 14:53
#747722
People still road race f9's
1980B4 1000
1978 Z1R
1978 B3 750
  • 80B4
  • 80B4's Avatar
10 Nov 2016 14:54
#747723
1980B4 1000
1978 Z1R
1978 B3 750
