cdi wiring
  • oldie
  • oldie's Avatar Topic Author
cdi wiring
17 Oct 2016 09:39 - 17 Oct 2016 09:41
#745429
Hi all still working on my 1982 kz250 . His baby has apparently a cd/ignition module (no points), and I've yet to get some spark.
I replaced the obviously failed module with a supposedly working used one on obtained on ebay. Im needing wiring from bike to connector as I had a diagram from a manual and began switching wires in connector and now misplaced the diagram. I've also replaced the trigger pickup inside the left side cover figuring previously that it was the culprit for not firing the coil. Still have no luck.
So hopefully someone has a wiring diagram or a link to same. would like to hear this li'l one run yet?
Thanks,
Ron
Last edit: 17 Oct 2016 09:41 by oldie. Reason: spelling
  • haha10024
  • haha10024's Avatar
Re: cdi wiring
28 Oct 2016 17:59
#746408
kz750twins.com/?p=426
That link should take you to a download for KZ250/305 service manual. I've been using it to work on my '87 kz305 and it's been helpful so far. There are plenty of wiring diagrams in there, so hopefully you can find what you need.
The following user(s) said Thank You: Patton
  • oldie
Re: cdi wiring
29 Oct 2016 07:42
#746439
Hey haha thanks for the info not sure if that'll help as my 250 is a single not a twin?
