Plug wire connect
Re: Plug wire connect
03 Oct 2016 16:10
It comes out easy with a small screw driver.
03 Oct 2016 18:35
Here's the clip.
Last edit: 03 Oct 2016 19:27 by Patton.
- stokes
- KZB2 650
04 Oct 2016 04:43
That shows it pretty well Steve...... on the 650 its probably only a half inch or just over in the coil just like the Suzuki coil Ness shows..... but pretty much the same principle.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
04 Oct 2016 06:29
The wire removal process may be assisted by working a little WD-40 down into into the cavity. If you could cram a small wire or similar between the coil body and the wire and then squirt some WD-40 inside the cavity and then twist the wire around before pulling it for removal.
