Coil Upgrade?
  • Kirkpatrick
  • Kirkpatrick's Avatar Topic Author
Coil Upgrade?
23 Sep 2016 18:49
#743350
Bike runs like a champ:
83 KZ550A4, pipe, jet kit, pods, smog block-off.
Is there a need to do a coil upgrade to an Accel coil or similar?
Thanks,
Brendan
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
Re: Coil Upgrade?
23 Sep 2016 23:00 - 23 Sep 2016 23:04
#743367
Kirkpatrick wrote: Bike runs like a champ:
Thanks,
Brendan
Nope.
An Accel brand coil is imo a good coil, but not necessarily an "upgrade." A good coil is a good coil. Whether it's Accel or factory Kaw or another of the known brands such as Dyna or Emgo or Andrews and likely others.
But if the coils are 33 years old, it's probably time to start considering new coils and perhaps also new spark plug wires.
More than one of us have limped to our destination on two cylinders when one of the coils failed. Sure beats pushing.
In any event, assure that the coils have a resistance value (ohms) as required by the ignition. The specs for a stock ignition will be covered in the Factory Service Manual (FSM). If the ignition has been replaced with a Dyna-S, a 3 ohm Dyna coil is recommended by the Dyna folks.
Good Fortune! :)
Last edit: 23 Sep 2016 23:04 by Patton.
  • JoHNY
  • JoHNY's Avatar
Re: Coil Upgrade?
24 Sep 2016 11:34 - 24 Sep 2016 11:35
#743412
I recently bought and fitted some new standard coils, leads and caps. Well worth the expense IMO
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
Last edit: 24 Sep 2016 11:35 by JoHNY.
  • Kirkpatrick
Re: Coil Upgrade?
24 Sep 2016 11:59
#743413
JoHNY wrote: I recently bought and fitted some new standard coils, leads and caps. Well worth the expense IMO
When you say standard, do you mean stock or aftermarket?
1983 Kawasaki KZ550
1997 Honda CR500
  • JoHNY
  • JoHNY's Avatar
Re: Coil Upgrade?
24 Sep 2016 15:21
#743431
Stock
  • Kirkpatrick
Re: Coil Upgrade?
08 Oct 2016 18:25 - 08 Oct 2016 18:28
#744812
Other than stock, can someone recommend a good "universal" 3 ohm direct replacement. I have searched but I am scrambling my brain at this point. I am looking at about 200.00 for NOS coils from Kawasaki. I mean if I have to bite the bullet on NOS, I will but would like to know other options out there. I know KZ part numbers are different on coils but will some work with others. I found the same to be true on my older CR500 dirbike with rims. Even though the part numbers were different, the still fit. For example, will the LTD 550 coil work?
LTD 550
1983 Kawasaki KZ550
1997 Honda CR500
Last edit: 08 Oct 2016 18:28 by Kirkpatrick.
Re: Coil Upgrade?
08 Oct 2016 18:38 - 08 Oct 2016 19:02
#744815
Z1E lists the pair of Dyna 3Ω ignition coils for $139.
Click here > www.z1enterprises.com/product/DYDC3-1
Good Fortune! :)
EDIT -- here's the link for DUAL out put coils:
www.z1enterprises.com/product/DYDC1-1
Last edit: 08 Oct 2016 19:02 by Patton.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Kirkpatrick
Re: Coil Upgrade?
08 Oct 2016 18:48
#744817
Patton wrote: Z1E lists the pair of Dyna 3Ω ignition coils for $139.
Good Fortune! :)
Thanks but those are single output. Need dual.
1983 Kawasaki KZ550
1997 Honda CR500
Re: Coil Upgrade?
08 Oct 2016 18:53 - 08 Oct 2016 19:05
#744819
The Dyna ignition coils may be mounted with the spark plug wires exiting forward or exiting toward the rear (at least on the large fours).
In this example, the spark plug wires exit forward, which is how stock ignition coils are routed from the factory (at least on the large fours).
Good Fortune! :)
Last edit: 08 Oct 2016 19:05 by Patton.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Coil Upgrade?
08 Oct 2016 18:59 - 08 Oct 2016 19:04
#744822
Good Fortune! :)
Oops! Sorry :( -- I meant to show the following link for dual output versions. Same $139 pricing for the pair.
Good Fortune! :)
Last edit: 08 Oct 2016 19:04 by Patton.
