81 440 ltd no spark
- BlackAngel915
81 440 ltd no spark
28 Aug 2016 17:08
Just got this bike and wanna make it into a bobber. So its been sitting for a while it cranks but no start. Checked coil its getting power . I am new to the kz world what else should I ck?
Re: 81 440 ltd no spark
28 Aug 2016 18:10
Welcome, pics?
28 Aug 2016 18:40
Is there spark on both plugs?
- Kray-Z
- I need more power Scotty....
28 Aug 2016 22:37BlackAngel915 wrote: Just got this bike and wanna make it into a bobber. So its been sitting for a while it cranks but no start. Checked coil its getting power . I am new to the kz world what else should I ck?
Lots - take a plug out, put the plug wire back on it and rest the plug body (metal part) against the head, making sure it is contacting bare metal on the head, such as a head stud nut or bolt or a bare spot on a cooling fin. Don't hold the plug or plug wire with your hand - 10 000 volts hurts BAAADDDDD! Turn the ignition on, crank the engine in the "run" switch position and look for a spark across the plug gap (you might not see it if it is too bright outside). You should check both cylinders, one at a time, this way.
If you have power and ground to the coils and no spark, then the bike's electronic ignition system has a fault (I am assuming the '81 440 has an electronic ignition vs. points). Check the coil primary resistance against the factory specifications. If that checks o.k., then check the resistance of the crank trigger coils. In my experience, the crank triggers fail from age and vibration first, as they are mounted on the engine. If the triggers check out, then the CDI unit might be the problem. Of course, you should check for continuity between the components through the wiring harness and all the connectors.
Hope that helps....
- BlackAngel915
08 Sep 2016 14:47
So test one plug at a time no spark on either . tested coil cked out ok gonna ck pick up next but looking for the specs on that ?
08 Sep 2016 14:55
How tested?
Is full battery voltage being received at coil primary terminal?
How tested?
- BlackAngel915
15 Sep 2016 18:16
Ok guys sorry been a while so i took out one plug at a time n touching thr motor i crank it n they both havr spark but still no start i cked coil with a meter and as the info i found cked out ok anything. Else i might be missing
16 Sep 2016 10:11
Three requirements are:
Spark --- Compression --- Fuel
Spark could possibly be okay.
Would next consider compression.
Compression test?
Valve clearance within specs?
Compression test?
