What spark plugs do I need
  • Danfarley1
  • Danfarley1's Avatar Topic Author
24 Aug 2016 18:34 - 24 Aug 2016 18:35
#739816
B) Hi guys need a bit of help I have a engine number of
Kz550ae027970
With spark plugs
Ngkd8ea
I am 100% sure these r the wrong spark plugs but when I look at the Haynes it doesn't give a proper answer of which I should be using
Last edit: 24 Aug 2016 18:35 by Danfarley1.
  • Nessism
  • Nessism's Avatar
Re: What spark plugs do I need
24 Aug 2016 18:39 - 24 Aug 2016 18:46
#739819
First of all get a proper manual for your bike - the factory Kawasaki service manual. There are free downloads available if you look around and search this site.
Regarding the spark plugs, D8EA is correct for most KZ550's. I believe that means that you are 100% incorrect. :side:
Found the download link for you... gpzweb.s3-website-us-east-1.amazonaws.com/Mnls/Mnls.html Throw that Haynes manual in the fire starter box and put the paper to good use.
Last edit: 24 Aug 2016 18:46 by Nessism.
  • Danfarley1
24 Aug 2016 18:54
#739820
I joined this page for a bit of helpful advise not dick answers. The zx550 a1 uses a NGK DPR9EA-9
The KZ550 A3 uses a NGK DR8ES and the laters use the D8EA
Which I think is the wrong year for my engine
I believe my engine to be a A2 engine
With little mention to this in the manual is why I came to this page
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2016 19:03 - 24 Aug 2016 19:04
#739823
Clymer gets a lot of guys in trouble. You need a FSM. Ed and a few others know more about the small fours than I do so I listen to them. B)
Last edit: 24 Aug 2016 19:04 by SWest.
  • Danfarley1
24 Aug 2016 19:06
#739824
Cheers
FSM ?
  • Danfarley1
24 Aug 2016 19:07
#739825
Does any one have a FSM
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2016 19:07
#739826
Factory Service Manual. Loud has the downloads in his signature. ;)
  • Nerdy
  • Nerdy's Avatar
24 Aug 2016 19:49
#739831
Nessism wrote: First of all get a proper manual for your bike - the factory Kawasaki service manual. There are free downloads available if you look around and search this site.
Yeah, the Haynes manuals are pretty terrible. My preferences: a paper copy of the factory service manual would be ideal, followed by a paper Clymer manual, and then the electronic copy of the FSM. The price is right for the last one but it's not as easy to search in my opinion.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
24 Aug 2016 20:00
#739834
Z1 Enterprises lists D8EA for 1981 KZ550-A2.
Good Fortune! :)
  • loudhvx
  • loudhvx's Avatar
25 Aug 2016 06:53
#739874
Like Ed and Patton said, you want the D8EA plugs assuming it's a Kz550A2 or USA KZ550A3 model. Canada and some parts of Europe got the resistor plug on the Kz550A3.
The Zx and Zr bikes are not officially Kz's.
It's more important to know what you have in case the previous owner changed something.
The only issue is whether the spark plugs are resistor or not. You can determine what you need, regardless of what the manual says, by measuring the resistance of your plug wires and plug caps. If either one has high resistance (and was designed to have high resistance, you use the D8EA plugs. If both, wires and caps, are non-resistor, then you use the resistor plugs DR8ES.
The link Ed provided will get you to the various online manuals. I suggest you download all of them.
  • Danfarley1
25 Aug 2016 07:28
#739881
Thanks very much. I'm in the uk the engine is on a old chop so I don't know what it really came from
  • loudhvx
  • loudhvx's Avatar
25 Aug 2016 12:02
#739913
If you are planning on buying new plug wires, then you decide what you like better, resistor-wires (aka suppression-wires), or resistor caps (that's what connects to the plug), or resistor-spark-plugs. Only one of those three options should be resistor. The other two should be non-resistor.
I prefer resistor wires. They are usually very available at any parts store. I've had bad luck with resistor caps and resistor plugs failing, but others prefer them.
