79 C3 - running lights don't work?
- Guzziman
22 Aug 2016 16:03
Hi all,
Recently found low mileage totally stock c3.
Parking light turns on rear brake light.
Switching on turns on headlight but rear tail light doesn't work, tach and speedo don't light up.
Also, hazard switch doesn't work but turn signals are fine.
I have looked at wiring diagram and tried cleaning connectors at major junctions in headlight and for rear tail light. Not sure what to go chasing at this point. I do have a pigtail tester and ohm tester. Just wondering if someone has experienced similar issue.
The harness is untouched and the headlight was converted to h4 bulb at some point.
Thanks
Bruce
Thanks
Bruce
- westmiltonfab
Re: 79 C3 - running lights don't work?
08 Sep 2016 13:11
Check your grounds. I have found out most electrical problems can be solved that way. The hazard thing sounds like the switch in my humble opinion
1980 Kz1000 A4 21000 miles
2005 Road King 150,000 miles
1968 CL125 Honda 11,000 Miles
