Coil issue
  • Dirtscootz153
  • Dirtscootz153's Avatar Topic Author
Coil issue
27 Jul 2016 15:43
#736413
I'm running a Kz 1428 in a hill climb bike. I have a dyna ignition system and dyna I believe 3 amp coils the green ones. I have tried testing them and get sine inconsistent results when I warm them I'm pretty sure coils are my electrical issue. For a high performance motor am I better off getting new green coils or something different?
  • MFolks
  • MFolks's Avatar
Re: Coil issue
27 Jul 2016 16:03
#736414
How old are the ignition coils? Running the factory resistive sparkplug caps? Dyna makes a non resistive,copper ignition leads(sparkplug wires). Are the primary(small gauge wires) tight? If longer screws are used,the screws can bottom out,before being tight. Accel makes a similar ignition coil that should fit,if you need to replace the Dyna coils.
  • Dirtscootz153
Re: Coil issue
27 Jul 2016 16:19
#736419
The bike was built probaly ten years ago. But doesn't get rode more then a few times a year. Primary wires I believe to be 14 gauge. Secondary or spark plug wired are a custom plug and cap set up only a couple years old. Bike has ran flawless for last 5 years but last race completely died and runs horrible soon as it warms up.
  • MFolks
  • MFolks's Avatar
Re: Coil issue
27 Jul 2016 16:32
#736421
Are the primary wire terminals properly crimped? Using a pair of vice grips as a crimper, will eventually cause the terminal to fail,or become intermittent.
www.pbase.com/image/93309736 (The good and bad of electrical crimping tools).
  • Dirtscootz153
Re: Coil issue
28 Jul 2016 06:53
#736479
MFolks wrote: Are the primary wire terminals properly crimped? Using a pair of vice grips as a crimper, will eventually cause the terminal to fail,or become intermittent.
There not bad connections. I'm going to redo all of them tho w heat shrink crimps because I don't like the looks of their connectors.
  • Barry2
  • Barry2's Avatar
Re: Coil issue
28 Jul 2016 07:13
#736481
I got tired of wires pulling out of connectors or breaking off at the crimp so now I pull the insulator off and solder them and use shrink tube.
1976 KZ900
