Wiring Help
  • Hamman
  • Hamman's Avatar Topic Author
Wiring Help
22 Jul 2016 14:48 - 22 Jul 2016 14:59
#735884
Hey Guys, I recently picked up a 1981 KZ750. There was no harness with the bike. I bought a 1982 KZ750LTD harness on eBay for dirt cheap. So far most of the main wiring works, but both LH & RH combo switches have different connectors. My main issue and I have looked at about 5 different wiring diagrams, I am trying to figure out what main wires I really need from the RH Combo switch to use the electric start. Ive looked online for 82-on RH control switches and they are pretty nonexistent. From looking at the E3 diagram which states it's for the 1982 it appears the starter button assembly only consists of 3 wires (black, red and yellow, which turns into a red/yellow). I am thinking i can get a universal switch with either 2 or 3 wires and figure out which two make the switch active. Thanks guys.
1981 KZ750LTD H2
Last edit: 22 Jul 2016 14:59 by Hamman. Reason: adding info..
  • MFolks
  • MFolks's Avatar
Re: Wiring Help
22 Jul 2016 16:05
#735893
The following user(s) said Thank You: Hamman, Redman79
  • Hamman
Re: Wiring Help
27 Jul 2016 11:21
#736385
Trying to figure out what this plug is for. Cannot seem to locate it on any of the schematics.... Thanks
1981 KZ750LTD H2
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: Wiring Help
27 Jul 2016 12:44
#736395
I've got a switch and the correct harness for an 81 750Ltd along with some other assorted stuff for the same bike.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • Hamman
Re: Wiring Help
27 Jul 2016 15:29
#736411
The Gringo wrote: I've got a switch and the correct harness for an 81 750Ltd along with some other assorted stuff for the same bike.
Really!!? How much would you like for the harness, and is it in decent condition? Thanks
1981 KZ750LTD H2
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wiring Help
27 Jul 2016 20:54
#736450
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI ordered new connectors for my loom.
  • martin_csr
  • martin_csr's Avatar
Re: Wiring Help
28 Jul 2016 04:03 - 28 Jul 2016 04:04
#736456
Z1Enterprises.com has a pretty good selection of connectors & electricals including colored wire which would be handy.
CycleTerminal is another place that also has a good selection, but the guy is on vacation right now until Aug 1. The connector quality is pretty good & they seem to be exactly the same as stock, the ones I got anyway. I think they are made by oem mfgs.
Last edit: 28 Jul 2016 04:04 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wiring Help
28 Jul 2016 05:07
#736459
They don't have them anymore.
  • martin_csr
Re: Wiring Help
28 Jul 2016 05:51
#736466
Don't have what any more? If you mean the 9-pin, Cycleterminal has them in white, black or blue.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wiring Help
28 Jul 2016 06:16
#736469
Z1E had them for the Z1/KZ 1000's. No more. I looked at that site, wrong style. I found the ones I showed and got them in 4 days. They have the other styles as well.
  • martin_csr
Re: Wiring Help
28 Jul 2016 06:41
#736476
Thanks. Do you just not care for the style, or will those connectors not work with the stock terminal pins?
  • MFolks
  • MFolks's Avatar
Re: Wiring Help
28 Jul 2016 06:46
#736477
www.easternbeaver.com is another website with motorcycle electrical supplies.
