I'm cunfuzed
  • Willy1803
  • Willy1803's Avatar Topic Author
I'm cunfuzed
20 Jul 2016 17:22
#735659
I have a 1977 kz650 which loses all power randomly an comes back randomly
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: I'm cunfuzed
20 Jul 2016 17:36
#735661
Bad connections or fuel restriction?
  • missionkz
  • missionkz's Avatar
Re: I'm cunfuzed
20 Jul 2016 18:03
#735665
Willy1803 wrote: I have a 1977 kz650 which loses all power randomly an comes back randomly
If not electrical....
Possibly fuel starvation from tank to carbs,
Fuel bowls run low, engine craps out, engine requires very little fuel to limp on and then bowls get a chance to refill a bit.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Re: I'm cunfuzed
20 Jul 2016 18:06
#735666
Check for kinks in the fuel line.
Check battery cable connections at both ends.
Is the battery good or old? A bad battery in a 1977 KZ650 can cause symptoms similar to those you describe. Ed
  • allfixed
  • allfixed's Avatar
Re: I'm cunfuzed
20 Jul 2016 20:17
#735685
Remove the Tank, Headlight, and sit down and unplug and re plug every connection you can find, checking for melting or corrosion at the same time..
Milwaukee wi.
  • Willy1803
Re: I'm cunfuzed
20 Jul 2016 23:15
#735695
By loose all power I mean electrical power all the light's go out
  • missionkz
Re: I'm cunfuzed
20 Jul 2016 23:35
#735696
Willy1803 wrote: By loose all power I mean electrical power all the light's go out
Check the fuse holders for corrosion or looseness... Etc.
Bruce
1977 KZ1000A1
  • Willy1803
Re: I'm cunfuzed
21 Jul 2016 13:35
#735759
Can someone tell me what this is an why it is smoking
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: I'm cunfuzed
21 Jul 2016 13:38
#735760
It might be a hazard regulator. Unplug it and see what happens.
Re: I'm cunfuzed
21 Jul 2016 17:21 - 21 Jul 2016 17:29
#735769
That is the bike's rectifier, and it should NOT smoke. It converts the A/C current produced by the bike's alternator into D/C current used by the bike's electrical system. It contains diodes that can fail. The Kawasaki Service Manual contains simple instructions on how to test the unit. Later bikes have the rectifier and voltage regulator together in a combination unit, but the 1977 KZ650 models came with separate units. If yours has failed it can be easily replaced by one from www.oregonmotorcycleparts.com/Products.html . I replaced mine several years ago when it failed. Pictures of the original unit that came on my 1977 KZ650 are sown below. Ed
Attachment Rectifier01.jpg not found
Attachment Rectifier02.jpg not found
Attachment Rectifier03.jpg not found
Last edit: 21 Jul 2016 17:29 by 650ed.
