Replacement speedo options? 82 KZ1100
  • psycobilly
  • psycobilly's Avatar Topic Author
19 Jul 2016 22:29
#735511
Just wondered if there is a plug and play replacement speedo available for an 82 KZ1100? I'd like one that actually registers above 85mph.. Since the gauges are electronic, can I use a late model cluster off a Ninja or something similar?
1982 KZ1100A2 57k miles, vetter fairing
  • martin_csr
  • martin_csr's Avatar
Re: Replacement speedo options? 82 KZ1100
20 Jul 2016 05:48 - 20 Jul 2016 08:02
#735524
From eebbaay UK but the seller doesn't ship to the USA. just to show that there is a plug n play option. If a meter housing is in poor condition, swapping the innards might be possible. just in case you find another one in similar condition.
KZ1100 SPEEDOMETER, TACHOMETER AND FUEL GUAGE
Last edit: 20 Jul 2016 08:02 by martin_csr.
The following user(s) said Thank You: psycobilly
  • baldy110
  • baldy110's Avatar
20 Jul 2016 09:22
#735568
Koso R1 gauge, very nice and clean setup. It is not plug and play, had to fab up the mounts and wire it in but it is really accurate and has tach, speedo, fuel, oil light, speeding light, and a bunch of other stuff I don't use. It even has an accelerometer built into so I can get horsepower readings, 1/4 mile times, 0-60 times, etc.
[IMG
  • psycobilly
23 Jul 2016 13:11
#735984
baldy110 wrote: Koso R1 gauge, very nice and clean setup. It is not plug and play, had to fab up the mounts and wire it in but it is really accurate and has tach, speedo, fuel, oil light, speeding light, and a bunch of other stuff I don't use. It even has an accelerometer built into so I can get horsepower readings, 1/4 mile times, 0-60 times, etc.
[IMG
How much does something like that run? I was hoping to find one cheap(ish), but if not I'll just have to save up
  • baldy110
  • baldy110's Avatar
24 Jul 2016 14:16 - 24 Jul 2016 14:17
#736068
I paid $350,00 for it and have about 6 hours to wire of in.
Last edit: 24 Jul 2016 14:17 by baldy110.
  • psycobilly
25 Jul 2016 12:38
#736185
That's not too bad. I'll have to start saving up...
  • martin_csr
25 Jul 2016 14:13 - 25 Jul 2016 14:17
#736195
Mechanical drive speedometer & electronic tach. KZ1000-P Police gauge cluster
eebbaayy search = kz1000 police speedometer -fit
Last edit: 25 Jul 2016 14:17 by martin_csr.
  • psycobilly
26 Jul 2016 20:29 - 26 Jul 2016 20:32
#736347
martin_csr wrote: Mechanical drive speedometer & electronic tach. KZ1000-P Police gauge cluster
Would that work on my 82 KZ1100A? Mine has the separate odometer/tripmeter and I thought the 1100 speedos were all electronic?
Attachment KZ(3)-2-3.jpg not found
Last edit: 26 Jul 2016 20:32 by psycobilly.
  • martin_csr
27 Jul 2016 05:29 - 27 Jul 2016 07:12
#736361
I took a look at the diagram of a shaft drive model front hub a couple of weeks ago, and from a quick glance the stuff looks the same as the mechanical speedo hub on the 1000P. You could do a comparison at Partzilla to see if the stuff is the same. I would get a speedo drive gearbox & receiver and do a test fit.
Last edit: 27 Jul 2016 07:12 by martin_csr.
