Cheap Spark Plug Wire Splice ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
01 Jul 2016 17:02 - 01 Jul 2016 17:03
#733547
I know it's probably just a batch job, but my #4 spark plug wire on my 77' KZ1000A is a little short in length. Even routing it the shortest way to the new angled spark plug cap I have, the wire just allows the cap to screw into it. Not banjo string tight but hardly any play with the wire.
A cheap and easy way to repair this I think, would be using a short sharpened finishing nail and driving one side into the stock wire leaving the coil about an inch from the coil. Then attach a new section of solid core copper wire to other side of the finishing nail in the additional length that I need. Then use some shrink wrap to insulate the joining wire ends.
Good idea or Bad idea ? :) :(
Or is using the NGK spark plug wire splice better ? :unsure:
77' KZ1000A
Last edit: 01 Jul 2016 17:03 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Cheap Spark Plug Wire Splice ?
01 Jul 2016 17:18
#733549
Switch coils?
  • kzdcw
  • 77' KZ1000A
01 Jul 2016 18:59
#733553
I think you mean " swap coil locations " to see if that will give me a little more spark plug wire length ? Or do you mean "replace " the coil that has the shorter spark plug wire ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jul 2016 19:44
#733557
I meant to see if the wires will reach it the coils are on the other side. I have a set some moron cut so they would only fit one way. I was planning on replacing the wires. That meant I would pull out the old ones and Epoxy the new wires in. It would work but I got a new set.
  • kzdcw
  • 77' KZ1000A
01 Jul 2016 20:05
#733558
Steve, I was going to try and switch the coils tomorrow and see if #4 wire which is too short would work better mounted on the right side of the frame backbone instead of the left where it's at now ?
Or I guess I could look at the electrical diagram and see if I could leave the coils where that at now and just switch the bullet connectors ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jul 2016 20:08
#733559
On the other side could give you more reach.
  • Nessism
  • Nessism's Avatar
  • Away
01 Jul 2016 20:20 - 01 Jul 2016 20:38
#733560
NGK sells wire spice thingies for the ignition leads.
You can pull the wires out of the coils too. There is a spike thing down on the bottom of the socket that the wire fits down into. If the wire tears you can use a pick tool and dig the old wire out. When installing new wires use WD-40 and shove the wire in good and hard to make sure the spike thing penetrates into the new wire.
Last edit: 01 Jul 2016 20:38 by Nessism.
  • z1kzonly
  • z1kzonly's Avatar
01 Jul 2016 20:32
#733561
What you want to know!!!
Yes! You can splice spark plug wires. I have did this plenty of times in the 70's and 80's.
I was too cheap to buy good items! So, the Muscle Car Guys always had Accel wires. I always took the short cut off's.
So, I would splice into the stock oem coil. I soldered the wire. A small piece of shrink tube! Then I wrapped 3M electric tape around it.
I still had points. It worked fine for years!
I looked cool! with my yellow Accel wires & orange plug boots!
This is what I did! And it worked! For Years!
  • martin_csr
  • martin_csr's Avatar
02 Jul 2016 06:25 - 02 Jul 2016 08:19
#733586
If he has the stock coils, the spark plug wires are molded into the coils.
edit: I did not know they could be pulled out. never saw that before. doh.
Last edit: 02 Jul 2016 08:19 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jul 2016 06:33
#733587
They are glued in. They will come out and new wires put in with epoxy. I have three sets of 30-40 year old coils. I saw no value in fixing old coils so I got new ones. :whistle:
  • KZB2 650
  • KZB2 650's Avatar
02 Jul 2016 06:55
#733591
I pulled my wires outta the stock coils and pushed in yellow copper cores for a while too before I bought the Dyna's. Maybe measure the depth and mark em so your sure they are bottomed out.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • kzdcw
  • 77' KZ1000A
02 Jul 2016 09:35
#733604
What do you Guys think of the idea using a finishing nail sharpened on both ends and using that to connect the wires as I suggested earlier in this Post? At least you wouldn't have to dig out the wire that goes into the coil.
The NGK splice looks good. Has anyone used one with good success ? Would this splice add anymore additional resistance in the system ?
77' KZ1000A
