Which wire harness to buy?
  • Hamman
  • Hamman's Avatar Topic Author
01 Jul 2016 12:29
#733527
No eBay APP ID and/or Cert ID defined in Kunena configurationHey guys. Just picked up a 1981 kz750 (4). Bike came with no wire harness. I've been doing some reading trying to decide what years and models may work for me. On eBay there are a ton of 81-82 spectre harnesses and a few KZ harnesses. On partzilla.com it says the 81-83 all use the same harness. The bike has some goodies on it already, Vance and Hines exhaust, dyna ignition and a radial master cylinder. Does any one if this harness will work!? Thank you all and can't wait to start contributing. ;)
1981 KZ750LTD H2
  • martin_csr
  • martin_csr's Avatar
Re: Which wire harness to buy?
01 Jul 2016 12:42
#733530
Is the bike a 750E standard or 750H Ltd?
  • Hamman
01 Jul 2016 15:05
#733540
Ummm.. Sorry but how can I tell? By the VIN #? Thanks!!
1981 KZ750LTD H2
  • martin_csr
01 Jul 2016 22:24 - 02 Jul 2016 05:54
#733565
CycleChaos.com has frame number & engine number info for many Kawasakis.
Zedder.com is another place, but you have to buy the software to get all of the available info.
The wire harness you linked is probably a close match, if not the same. you'll want as close a match as possible, although it may not matter too much. The 750E & 750 Ltd are probably very similar. The other 750-4 models probably aren't that much different either, but a close match would make it easier as the meters can be wired differently & maybe some other stuff. The ignition systems & charging systems are pretty much identical, as are some of the other electrics.
Manual. 750turbo.com --- Index .
1980-84 KZ750-4. 1983-85 ZX750. pdf manual. good scans.
Wiring diagrams. mbsween. bike-night. KZ750L3 . Scroll down & click "The Bible" link.
Note: some of the wiring diagrams are mislabeled in the links: the 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4.
Last edit: 02 Jul 2016 05:54 by martin_csr.
The following user(s) said Thank You: Hamman
  • Hamman
02 Jul 2016 05:52
#733582
Awesome man thank you!!! This info will help immensely. Looks like a lot of good reading. I'm out of town now but will go over the bike better one home. Not sure either but the Seats on the bike are super thin and dual, not a long solo style. I haven't seen anything like them online. So they may have just been recovered and cut. So do you think a harness from a spectre would work? I just need the basics really. Thanks again!!!!
1981 KZ750LTD H2
  • martin_csr
02 Jul 2016 05:56 - 02 Jul 2016 06:01
#733583
Yes, most likely. but I would compare the wiring diagrams if possible or some of the electrical components, such as the ignition switch & handlebar switches. some might suggest making your own wiring harness, but that can be a lot of work.
Last edit: 02 Jul 2016 06:01 by martin_csr.
  • Hamman
02 Jul 2016 09:02
#733603
Awesome, I'll be sure to check out the wiring in the switches when I get back home. There are quit a few nice harnesses from spectres on eBay for dirt cheap. Thanks again for all your help!
1981 KZ750LTD H2
