Tail light and front city light does't work
- shamal
27 Jun 2016 02:19
Fuse and lamps are fine. The only thing that work is high and low beam, and the stop light when the brake is pressed.
What else i can check?
1983 kz 550 h
- davido
Re: Tail light and front city light does't work
27 Jun 2016 04:18
I noticed on my bike (different model/year) there is a small diode coming off the rear light. It was missing and the wires just hung loose. Once I connected the 2 wires everything worked on the tail/brake light. Problem is,the diode is taped into the main loom (or should be) you have to fish around to find it.
Like I said,different model/year to yours so maybe it dosnt apply. Check your wiring diagram and see whats what.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: shamal
- shamal
27 Jun 2016 04:41
Thank you veru much. I have never seen this diode, i have to look near the tail lamp?
I have the manuale but i miss the wirings pages. Can someone post a pic of the wiring for the KZ 550 h? Gpz.
I was thinking about the switch in the handlebar but i noticed that the position light doesnt work neither with the key in parking position. So i guess the switch is good . is this assumption right?
1983 kz 550 h
- shamal
30 Jun 2016 14:06
Solved. Just the blue/red wire in the key switch connector broken. Fixed!
1983 kz 550 h
